D600 FX question
Discussion in 'Nikon Cameras' started by TwoRails, Nov 4, 2012.
  1. TwoRails
    TwoRails TPF Noob!
    Nov 9, 2008
    1,149
    The Great Northwest
    Just curious. I hear you can use the D600 as either DX or FX, but how does it work? By that I mean does it simply sense the lens you put on? ...or is there a switch / button to switch between the two?
  2. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    38,436
    14,202
    USA
    I am assuming that it works similarly to the way the D3x works, which is that it can be set to AUTOMATICALLY default to DX-sized image area whenever a DX-Nikkor is bayonetted onto the camera. OR the user can select the smaller DX-sized capture, at any time, with any lens, DX or FX lens, by pressing the FUNC button and turning the main control dial one click.
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    its automatic, or in the set-up (or shooting) menu you choose your area
  4. slow231
    slow231 No longer a newbie, moving up!
    Mar 11, 2011
    273
    45
    Maryland
    yes i think it's automatic with the nikon dx lenses. but maybe not so with 3rd party lenses. I know when I put on my tokina 11-16 it was shooting in full frame mode (which is actually what i wanted since that lens puts out a ff image @16mm).
  5. TwoRails
    TwoRails TPF Noob!
    Nov 9, 2008
    1,149
    The Great Northwest
    Great, thanks folks :)
  6. kosteger
    kosteger TPF Noob!
    Feb 7, 2013
    10
    Ohio
    Its actually only automatic if you set it to automatic in the custom setting menu. otherwise the function (FN) button on the bottom left serves as a FX-DX switcher thing so you press that then you move the front toggle (left or right) next to the shutter button. this feature is really helpful if you only have a wider lens like 50mm but you need a bit more reach then you can switch to DX crop mode.
  7. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    21,934
    7,833
    Iowa
    Factory default setting is to automatically detect DX lenses and shoot accordingly. You can, however, change that. To either shoot FX or DX regardless of the lens used.
  8. cwcaesar
    cwcaesar TPF Noob!
    Nov 26, 2012
    307
    52
    Middle Tennessee
    If you use an FX lens, won't you get the same effect if you crop in post?
  9. 480sparky
    Mar 8, 2011
    21,934
    7,833
    Iowa
    Yes, if you crop to the right pixel dimensions. ...3,936 x 2,624 pixels
change dx D600
change dx to fx d600
changing to dx on d600
d600
d600 choisir fx mode
d600 fx dx switch
dx/fx button
how to change dx to fx mode d600
nikon d600 fx settings
using function buttom nikon d600 dx fx
