D70 Cleaning
Discussion in 'Digital Discussion & Q&A' started by cleary71, Oct 31, 2005.
  1. cleary71
    cleary71 TPF Noob!
    Oct 26, 2004
    67
    I was hoping someone could suggest a safe way to clean my D70. I noticed several spots on some of my photos, which I originally attributed to the lens, but after switching out lenses I noticed that the spots were still there. If anyone could point in my in a safe and fool proof way to do this I would be very grateful. Thanks in advance!!
  2. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
  3. JonMikal
    JonMikal TPF Noob!
    Jul 28, 2004
    12,262
    327
    most everyone here would kill me, but i lift the mirror and blow. i'm sure it's not a good idea, but so far so good ;)
  4. Cdeep04
    Cdeep04 TPF Noob!
    Oct 26, 2005
    25
    Utah
    Depending, Canned air can work quite well. but so does a cotton swab and a little bit of alcohol or goo be gone. Just be gentle.
  5. SLOShooter
    SLOShooter TPF Noob!
    Dec 21, 2004
    421
    If your thinking about cleaning the CCD be very very careful they are quite fragile. I wouldn't blow with your mouth, no matter how hard you try you'll always end up with spittle in there. If you have a puffer I would give that a try, other than that I don't know, I've not tried physically touching the CCD.
  6. Patrick
    Patrick TPF Noob!
    Oct 2, 2003
    562
    Xenia, OH
    I use a rocket blower and if that doesn't do the trick I use brushes purchased from Visiable Dust. But 90% of the time the blower does the trick.
    Both work like a charm.
    I wouldn't, IMO, go with canned air.
  7. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    Lifting the mirror does nothing to clean the CCD as it is still behind a closed shutter. As far as the CCD from being fragile, there is a filter some call a "hot mirror" filter that is tinted blue to reduce "IR sensitivity and attached to the front of the CCD sensor. This filter is very resilant and does a good protecting the sensor. The fragile componet to watch out for is the open shutter. If the shutter should attempt to close while you clean the sensor, the shutter would surely be damaged and would result in an expensive repair bill. That said, I have cleaned my own D1, D1h and D1x for years.
