D700 problem!! Urgent HELP needed!!
Discussion in 'Beyond the Basics' started by Insp Gadget, Aug 28, 2010.
  1. Insp Gadget
    Insp Gadget TPF Noob!
    Aug 23, 2009
    65
    Fredericton, NB, Canada
    My wife and I are shooting a wedding today and it seems the D700 took today to act up. 2 problems have surfaced.
    1. The camera (occasionally) will not focus and release the shutter. If we shut it off or switch lenses it works again.
    2. The flash will fire the modelling flash by itself. Also, the flash will not fire by itself occasionally.
    Both the lenses and flashes work fine on our D300, so it appears that the D700 is acting up.
    I have tried the 2 green button reset, but the problems remain.
    Has anyone seen this happen and can anyone suggest a way to work around this for the wedding?
    Thanks!
  2. KmH
    Apr 9, 2009
    40,724
    5,587
    Iowa
    The work around is to use the backup camera.
    Do you switch lenses without turning the camera off?
    • Like Like x 1
  3. Insp Gadget
    Aug 23, 2009
    65
    We are using a D90 as a backup, however the D90 doesn't produce as good a result as the full frame D700 which is why we are trying to get it working properly.
    Yes, I change my lenses all the time without turning off the power. Does this affect anything?
  4. KmH
    Apr 9, 2009
    40,724
    5,587
    Iowa
    Yes, it can fry your electronics from capacitive discharge, which is why all Nikon users manuals say to turn the power off before you change a lens.
    Page 37 in the D700 users manual.
    • Like Like x 1
  5. SwiCago
    SwiCago TPF Noob!
    Aug 23, 2010
    24
    Near Chicago
    It can, since the pins to the lens are active(powered) while the camera is on. If done too slow, this could cause unwanted shorts, which could potentially damage the camera. Page 37 of the manual clearly says to turn it off while exchanging lenses.
    You could also try to fresh the firmware. Maybe yours is corrupted somehow.
  6. Tony Sale
    Tony Sale TPF Noob!
    May 20, 2011
    Hi Insp Gadget - I am having exactly the same problem as you had with the shutter jamming. I never swap lenses with the camera swithced on so it can't be that. Did you find a solution to your problem? Tony
  7. Propsguy
    Propsguy No longer a newbie, moving up!
    Mar 20, 2011
    176
    31
    ontario, canada
    I know I;m late in responding to this thread... I hope you got through the wedding alright, but I had a similar problem with my D700 and it turned out that my battery was fried... I'm not sure if there was a dead cell in the battery and it wasn't providing the necessary voltage, but I suspect that was the case.... regardless, when I swapped in a new battery, did a factory reset and all returned to normal.
  8. Killbad
    Killbad TPF Noob!
    Oct 10, 2011
    San Francisco
    First off… I suggest finding a new line of work. You have no idea what you are doing. Anyone who shows up to a gig with a D90 should be shot. Second, RTFM.
  9. MissCream
    MissCream No longer a newbie, moving up!
    Sep 9, 2010
    1,855
    452
    Canada
    Dude this thread is from 2010.
  10. dots
    dots TPF Noob!
    Oct 8, 2011
    756
    24
    ..with a Sony Mavica. At dawn. Four times. To floppy disk.
  11. KmH
    Apr 9, 2009
    40,724
    5,587
    Iowa
    Then I must have done something wrong in 2009 when I had profit/income of $46,000 from images I made using a D90.
    • Like Like x 2
  12. RoeAnne
    RoeAnne TPF Noob!
    Jan 16, 2012
    Santa Barbara, CA
    I'm having the same problem with my D700. It's an intermittent problem. as I'm shooting the shutter release button goes "dead." sometimes it won't focus either. I turn off the camera when changing lenses. Does anyone have an explanation or solution for this problem?
d700 mirror stuck up
d700 shutter failure
d700 shutter not working
d700 shutter problem
d700 stuck mirror
how to fix nikon d700 stuck mirror
nikon d700 bug in shutter
nikon d700 shutter button nikon d700 flash problemwhen using with flash
nikon d700 shutter not work
shutter sticking d700
