2WheelPhoto
- Joined
- Apr 14, 2011
- Messages
- 6,844
- Reaction score
- 996
- Location
- Tampa
- Can others edit my Photos
- Photos OK to edit
Dare you to do research such as type "comparison d7000 d5100" in a search tool and see if it outputs useful info
I have both.
I prefer the D5100 for travel, hikes, and Video
The D7000 is much better for Event Photography, especially action.
D90, 18-105 VR, 70-300 VR, an SB600, and a 5 in 1 reflector kit. You can pick up that entire kit for what the D7000 plus 18-105 goes for. The d7000 just simply isn't that much better of a camera. If you just want new, go with the d7000. If you want the best value, go with a used D90.
IMO, the only people who should buy a D5100 are those that never plan to learn anything about photography, plan on leaving one lens on it, and using it as a big P&S.
Just my .02.
When I went down to my camera store to pick up a second D7000 for my EVENT Photography,I have both.
Why? The D7000 isn't that much bigger, and it is a whole lot more camera.
IMO said:I totally disagree.
Because the D5100 is much harder to use properly than the D90 or D7000.
I shoot in aperture mode not automatic
If you want a camera to set up like a P&S get a D3100 instead.
Just my .02.
I disagree with you here. Not on the d90 suggestions, as i think that is a worthwhile kit for a beginner (and money well spent) to learn about a DSLR, and the lenses cover a wide range.
However, the D7000 is a whole lot more camera than the D90.
D7000--16.2 Mpeg, Expeed 2 Image Processor, Native ISO (without boost) is 100-6400, Boost to 25,600, 39 AF Focus Points, 100% Viewfinder Coverage, MAx Shutter, 1/8000th, 6fps, 1080p Video, Weather Sealing (Well, weather and dust resistant).
D90--12.3 Mpeg, Expeed Image Processor, Native ISO (without boost) 200-3200, Boost to 6400, 11 AF Focus Points, 96% Viewfinder Coverage, Max Shutter 1/4000th, 4.5fps, 720p Video, No Weather Sealing.
IMO, the D7000 far outshoots the D90. I have used both, and it is obvious, once you pick up the D7000, it is a better camera by far.
I know the differences and I've also used both. I felt the D7000 as an upgrade/replacement was kind of a disappointment. I just don't think it's a good value, especially for a beginner on a budget.
In any case, everybody is certainly entitled to their own opinion. That's why Nikon/Canon/etc make so many different models of cameras at different price points. What I posted was just my opinion. Definitely not intended to be the end all/be all.
Just my .02.
And i as well. To each his own, sir.
Out of curiosity, if you had no gear at all and wouldn't be able to add anything for a while, which would you rather have? A d7000 and a kit lens or the kit that I outlined?
It really depends on what you are going to use the camera for.
If I could only have one camera, I would choose the D7000
they lined up a 3100, 5100, and 7000
I came home with a D5100 instead.
The articulating LCD is much better than I expected and very valuable for Video.
You can also zoom in on an object and check your focus when taking stills.
The 1080 Video at 30fps was the clincher.
Later I zoomed in on my big monitor and my landscape pictures seemed a little better quality (newer technology) to me.
