What the man said...........YeapYou are correct.
I found the 1.3 crop mode good only to bump my D7100 from 6FPS to 7FPS
Other then that you can just crop the file because that what you are really doing, cropping the sensor.
Crop mode also increases your burst ability, as well as reduce image file sizes.
If you're going to crop that much in post anyway, it's a no-brainer to shoot in 1.3x mode.
I guess that makes sense, my only problem was that you cant use the full size of the sensor and I was always afraid that the subject will get out of the frame, I found it not to be so intuitive for me.What the man said...........YeapYou are correct.
Turn on your viewfinder screen framing lines and you will see the crop framing lines ... at least on some models. I don't recall the specific function for it but I've used it before.
You get the field of view a 97.5 mm lens on a full frame (35 mm) camera would give.50mm x 1.5 x 1.3= ~97.5mm effect range?
100mm x 1.5 x 1.3= ~195mm effect range?
