If you dont use HSS (High Speed Sync, the ability of flash to operate beyond the flash sync limit, Nikon calls it AutoFP), you will never encounter it.Still don't know what the actual issue looks like.
1. You need to have an external flash that supports HSS.
2. You need to have HSS enabled in the camera.
3. You need to actually use HSS.
I definitely would have noticed if HSS wasnt working. After all, HSS is one of the main reasons why I switched from the D5100 to the D600, back in the day.
HSS allows you to use fill flash in bright sunlight. Thats what I'm using it for all the time. Well, during summer and when I'm doing portraiture.
P.s.: Oh, and instead of HSS one can use ND filters. Only issue though is you need quite a couple of them and select the right one and need time to screw it on. Well I guess a Variable ND filter is also possible.
I am utterly confused as to why ND filters are supposed to do anything like that ?!?so..how are those ND filters going to fix shadows and uneven lighting?
All that ND filters are supposed to do in that situation is to lower the shutter speed, so the camer would be able to operate below (or at) its flash sync speed and thus wouldnt need to use HSS. Thus neither the flash nor the camera would required to support HSS.
So for the 10 years I own that car, I did not need to spend a dime on the tires.
I tried to ask my "sales counter" but my computer monitor didn't speak back...
Those Bastards!My D750 is affected but I didn't see the issue in any of my photos. I sent in the camera anyway. I took four days, including shipping, to get it back to my hands. They even cleaned the sensor for me.
Dont forget the resale value issue as well.Do I only need to concern myself when (a) I rack up 100k actuations so get a new actuator and (b) I get a HSS flash. Mine is due back so I believe and it would involve me putting it on a plane to the UK.
