D80 600 flash question.
Discussion in 'Digital Discussion & Q&A' started by domromer, Nov 17, 2007.
  1. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    I have the d80 and the sb600 series flash. I've heard the d80 can control a flash not attached to my camera. I read the manual and I'm still a bit confused. Am I able to hold the sb600 off the camera and still fire the flash or do I need another piece of equipment. Or the sb800? If I can do this can someone give me a quick and dirt break down of how?
  2. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    pop up the d 80 flash, go into your menus, set the flash mode to commander, set the SB-600 to slave (they tell you in the manual) and you're golden.
    It's really easy and it works awesome.
  3. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    The flash needs to be set into "remote" mode, no SU-4, but actually "remote" and the manual should detail how.
    The camera needs to be set into commander mode. This is somewhere in your custom settings menu like inbuilt flash firing mode or something. The choice should be TTL Manual or Commander.
    Once in commander mode the external flash needs to have a channel and group selected, and the camera needs to be on the same channel, then you can specify settings for each group, and the inbuilt flash.
    When you push the button the camera will fire it's flash to send the required data to the remote units, then all flashes will do TTL metring, and THEN the exposure happens and the flashes fire.
    The sensor on the SB-600 must be able to see the light from the camera flash.
    /Edit: Dammit Switch beat me!
  4. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    grrr I still can't get it set up to work right.
  5. Aye-non Oh-non Imus
    Aye-non Oh-non Imus TPF Noob!
    Nov 18, 2007
    516
    23
    CAMERA:
    Power your camera on.
    Select the menu button (second from top on left side) on the back of your camera.
    Select custum settings menu (pencil icon)
    move selector up the menu to #22 built in flash and move selector to the right
    select c - commander mode and move selector to the right
    have built-in flash mode (first column) at --- (move selector up/down to find)
    channel = 3
    Press OK
    make sure the pop up flash on camera is up
    FLASH:
    Power flash on
    press and hold both zoom and - buttons for a couple of seconds. menu should appear.
    cycle thru until icon of a squiggly line with an arrow appears.
    if OFF is displayed push mode button once and ON will appear
    the 600 IR receiver needs to be able to see the preflash from onboard flash
    (not necessarily line-of-sight)
    now you can make adjustments as desired for your application
    That's it.
    Bob's your uncle.
  6. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    Thanks for the break down. I'll go home tonight and try it out.
