d80 flash sync question
Discussion in 'Digital Discussion & Q&A' started by domromer, Jan 17, 2008.
  1. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    Is there a place in the D80 to plug in a flash syc cable?
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    No you need a PC sync to hotshoe adapter. No matter though they are relatively cheap, work the flash the same way, and can be found all over the place.
  3. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    Thanks I'll look into that.
    My teacher sort of freaked my out by mentioning it's easy to fry you camera in the process. Is there anything I shouldn't do when hooking up my camera to a light set?
  4. bapp
    bapp TPF Noob!
    Dec 20, 2007
    114
    Blackpool
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Yeah make sure the flash unit is off when you connect it, and if your flashes were manufactured before the 90s I suggest you find out what the voltage of the terminals is. If it's more than 24V i'd take care with a D80. Even though the D80 should survive the higher voltages as far as I remember.
