d80 or d40
Discussion in 'Photography Equipment & Products' started by BuddyRockefella, Feb 12, 2009.
  1. BuddyRockefella
    BuddyRockefella TPF Noob!
    Jan 4, 2009
    5
    need help choosing. cant decide which camera to get narrowed it down to d80 with 18-135mm kit or d40 18-55mm kit d80 is $1199 and the d40 $$537.
    will be shooting mainly landscapes buildings, family, and some night photography.
    was going to get the d40 but the nightphotography is a consern due to stuff i read. dont mind having to manual focus.
  2. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    Anyone charing you 1200 for that D80 package is ripping you off.
  3. blash
    blash TPF Noob!
    Nov 19, 2008
    599
  4. sultan
    sultan TPF Noob!
    Mar 5, 2008
    302
    Mississauga, Ontario, Canada
    The D80 body is worth ~$700. Add another $100 for an 18-55 and you get $800 - that's what the D80 is worth. Now after knowing that, the rest is you get what you pay for. The D80 > D40 but the D80 is more expensive. Similarly D90 > D80 but D90 is even more expensive ($1000).
    The D40 is just fine for starting out; it'll do all you need. The D80 does more but you don't seem to need its capabilities. Maybe after a couple years you can upgrade to a D400 (once its out).
    For night photography, you need a good tripod the most. Also, film cameras are better than digital for night photography, but any camera (including the D40) will do just fine for most normal night photography (exposures of >10 seconds). It might get a bit noisy on longer exposures though.
  5. BuddyRockefella
    Jan 4, 2009
    5
    prices are in australian dollars
  6. sultan
    sultan TPF Noob!
    Mar 5, 2008
    302
    ah, my bad. Being Canadian, I was giving prices in Canadian Dollars. Even then, after converting currencies, the D80 kit seems about $200 more than what it should be.
  7. Txaggie08
    Txaggie08 TPF Noob!
    Mar 14, 2007
    150
    D80's are selling through ritz for 549.99, and a kit lens with vr is 149.99$. They did get a batch into the main warehouse in beltsville not long ago, so Nikon is shipping a few at any rate.
  8. potownrob
    potownrob TPF Noob!
    Jul 8, 2008
    312
    Poughkeepsie, NY
    You can get some decent deals if you're willing to go used. I picked up a slightly used D80 (body only) on ebay last night for 430 USD with shipping. They're going for a little more on keh.com (at least now; they were closer to 400 less than a week ago). When I bought my D40 w/ kit lens I paid under 400 and now it looks like you can get them for under 350 USD w/ the kit lens. I personally would get either D40 or D80 body only (unless you can find a good deal on D80 w/ the 18-55 VR) and try to get a lens with constant f/2.8 aperture (like the Tamron 17-50) or at least VR (18-55 VR). The Tamron runs around 300-400 USD and the 18-55 VR can be had for under 200 bucks. If you're only planning on shooting landscapes and family stuff, the standard zoom may be enough.
  9. BuddyRockefella
    Jan 4, 2009
    5
    got the d80. everywhere is sold out no d40 anywhere no d80s aswell got the last one . batt is charging now will post when batt is charged. thanks all for your help
  10. C.Lloyd
    C.Lloyd TPF Noob!
    Oct 22, 2007
    299
    Holly, Mi
    Hmmmm... choices, choices...
    If you're not doing anything professionally that might require a battery grip for extended run times, why not go for the D40? It'll do everthing you need it to for half the price. It's more compact, (I would assume) a little easier to use and can use all the same great lenses. Get the cheaper camera and spend money on the lenses. A friend of a friend of mine (as the story was related to me...) does model photography and just goofing around put one of her $2000 lenses on a "lesser" 6mp camera and when the shots were developed, was unable to tell the difference between them and the "pro" camera she normally uses at sizes up to about 11x14.
  11. C.Lloyd
    C.Lloyd TPF Noob!
    Oct 22, 2007
    299
    Holly, Mi
    P.S. I have the D80 and am happy with it, but now I'm in the situation where I would like to get a better lens that the kit that came with and I'm kinda outta cash. Had I gone with a $500 less expensive camera to begin with, I'd be able to get the lens I am now coveting...
  12. bhop
    bhop No longer a newbie, moving up!
    Dec 10, 2007
    2,211
    236
    Los Angeles
    D80 no question.
    D40 doesn't have a focus motor or top LCD display. Lack of focus motor means you won't be able to use older (cheaper) lenses. It will only focus with more expensive modern internal focus lenses. Top display is useful for showing you setting info on the fly. If these aren't important issues for you, then well... the d40's cheaper..
    edit.. just realized you posted saying you got the d80 already. Congrats.
