D90 Aggravation
Discussion in 'Photography Beginners' Forum' started by bc2292, Mar 25, 2010.
  1. bc2292
    bc2292 TPF Noob!
    Feb 25, 2010
    36
    Houston, Texas
    So i was taking pictures of flowers in doors today so i pulled out my SB-900
    and was trying to dark out the back ground so i wanted to speed up my shutter speed and light up the flowers with my flash. For some reason even in manual mode when i had my flash on the hot shoe it wouldn't allow me to shoot faster than 200/s. I took off the flash and triggered it and i could adjust my shutter speed all i wanted. Is there any getting around this?
    Thanks
  2. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    No, thats the max sync speed of the D90. No faster w/ flash, otherwise you will be getting a shutter blade shadow in your shot.
  3. iflynething
    iflynething TPF Noob!
    Oct 26, 2006
    1,346
    South Carolina USA
    Does the 90 not have FP sync like on the D300 and higher?
    ~Michael~
  4. AlexColeman
    Dec 13, 2008
    1,732
    It may, but I cant say for sure. He can always google it.
  5. KmH
    Apr 9, 2009
    40,542
    5,541
    Iowa
    Time to have another look at the ole D90 users manual.
    Look up FP flash sync mode. You'll have to look at the SB-900 manual too.
  6. mwcfarms
    mwcfarms No longer a newbie, moving up!
    Mar 16, 2010
    2,656
    179
    Southern Alberta
    looking at my book it says using the Auto FP (Focal Plane) high speed flash sync feature, it is possible to synch external speedlights compatible with the Creative Lighting System (CLS) at shutter speeds between 1/200 and 1/4000 second. This feature is only available in the P, S, A, and M exposure modes. Dont know if this helps or not but I was just reading this earlier.
  7. iflynething
    Oct 26, 2006
    1,346
    South Carolina USA
    You'll need to enable that on the camera, might say 1/320*(Auto FP) or something similar.
    It will also need to be set on the SB-900, I use the 800 and I think it's set differently on the 900
    ~Michael~
  8. bc2292
    bc2292 TPF Noob!
    Feb 25, 2010
    36
    Houston, Texas
    Thanks to all the responses i googled it. Seems like i'm limited to 200/s but i'll just trigger it with the pop up flash and try to survive :)
  9. mwcfarms
    Mar 16, 2010
    2,656
    179
    Southern Alberta
    Well i guess book is wrong then. :neutral:
  10. bc2292
    bc2292 TPF Noob!
    Feb 25, 2010
    36
    Houston, Texas
    No Bueno :thumbdown:
  11. iflynething
    Oct 26, 2006
    1,346
    South Carolina USA
    Under your flash sync speed do you have
    1/320s (Auto FP)
    1/250s (Auto FP)
    1/250s
    1/200
    .......and so on?
    If so, you need to select the top 1/320s (Auto FP) on your camera. Once this is done when you have your flash turned on, it will say [TTL][BL][FP]
    You should be set to go
    ~Michael~
  12. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
