D90 Automatically Moves While Bracketing
Discussion in 'Digital Discussion & Q&A' started by Lrk, Jun 3, 2010.
  1. Lrk
    Lrk TPF Noob!
    Mar 15, 2010
    4
    Timisoara
    While i was working on a HDR timelapse i noticed something strange.
    I was using the 3 step bracketing (since the D90 doesn't have a firmware update to a 5-step as far as i know). The D90 was mounted on a very firm and stable tripod. The first of the 3 shots (under) of each set was always pointed slightly downwards, the other 2 were perfectly aligned. After taking the 3rd shot it would immediately move back down again even if the next set was several seconds away.
    It's not a big problem, but i can't find the cause. I tried to look at the camera when it was taking the shots, but it doesn't seem to move.
    I drew a line were the top of the chimney was suppose to be.
    [​IMG]
    [​IMG]
    [​IMG]
    OfftopicPS: Yeah, i noticed the buildings were underexposed, so i changed it a little in the next sets.
  2. pbelarge
    pbelarge TPF Noob!
    Feb 11, 2010
    2,680
    New York
    My T1i did a very similar thing with bracketing. The third shot of bracketing was off by a hair and usually out of focus.
  3. KmH
    Apr 9, 2009
    40,552
    5,544
    Iowa
    The EXIF for the 3 images all show 1/4000, f/11, ISO 200, -2EV, Manual mode, Matrix metering.
    Something doesn't compute.
  4. Lrk
    Lrk TPF Noob!
    Mar 15, 2010
    4
    Timisoara
    I loaded them as layers in Photoshop, added a 4th for the line (so it's in the same place) and then exported the layers manually. It's probably from there.
  5. NateS
    NateS TPF Noob!
    Sep 27, 2007
    2,753
    40
    Missouri
    AF or MF? I'm guessing AF and the image will change just slightly when focus changes.
  6. robertwsimpson
    robertwsimpson No longer a newbie, moving up!
    Aug 3, 2009
    2,471
    30
    West Palm Beach, Fl
    I'll bet you had it on AF and AI Servo (or whatever the Nikon equivalent is called)... Just flip to MF for autobracket shots. Problem solved!
  7. supraman215
    supraman215 TPF Noob!
    Oct 25, 2006
    979
    12
    Philadelphia
    Robert means turn VR off.
  8. robertwsimpson
    Aug 3, 2009
    2,471
    30
    West Palm Beach, Fl
    No, I'm pretty sure I meant turn AF off. Turning VR off would also be a good idea... I assume everyone does that when using a tripod.
  9. KmH
    Apr 9, 2009
    40,552
    5,544
    Iowa
    Good call. :thumbup::D
  10. Lrk
    Lrk TPF Noob!
    Mar 15, 2010
    4
    Timisoara
    I may be noobish, but i'm not that noobish. It was on manual focus. But VR was on. I'll give it a test run tomorrow and let you know. Thanks.
  11. supraman215
    Oct 25, 2006
    979
    12
    Philadelphia
    Focus will not MOVE an object that's why I thought Rob meant VR. It may bring a blurry object into focus therefore moving the edge of the object closer to the object's center but that building was in focus to begin with.
  12. robertwsimpson
    Aug 3, 2009
    2,471
    30
    West Palm Beach, Fl
    Do an experiment. The view through my lenses changes slightly when focusing. I'll bet yours do too.
