D90 Commander mode question
Discussion in 'Photography Beginners' Forum' started by hankejp, Aug 15, 2009.
  1. hankejp
    hankejp TPF Noob!
    Aug 24, 2008
    608
    Wausau, Wisconsin
    So I'm trying to play with the commander mode on my D90. And sometime the off flash wouldn't fire.
    I had the flash off to the right and in front of the camera about 10 feet away. It was sunny out where I had the camera and flash. The sensor was in view of the on camera flash but the external flash wouldn't fire.
    Any ideas? Is it possible that it was too bright out for the exernal flash to fire. I put the same setup in my garage and it was firing normal.
    Hope I explained it good.
    Thanks
  2. thenikonguy
    thenikonguy TPF Noob!
    Jul 26, 2009
    589
    I know next to nothing about commander mode, as my camera doesn't have it, BUT, I do believe that commander mode works best indoors.. and here's why.. commander mode works on a "slave" premiss.. so what happens is, your camera built in flash, fires(dimly) which then triggers the slave on the external flash, which causes it to fire.. if you are outside, on a sunny day, and your cameras built in flash fires dimly, the sun can over power it, and thus, the slave on the external flash will not see it.
    Now, I could be totally wrong here, as I said, I don't know anything about commander mode.. but, thats my guess.
  3. hankejp
    hankejp TPF Noob!
    Aug 24, 2008
    608
    Wausau, Wisconsin
    Thank you for the response. That was my best guess as well. I had the onboard flash set to disabled so it wouldn't show up in my shot. I never tried it using a different EV.
  4. thenikonguy
    Jul 26, 2009
    589
    if you set your on board flash low enough, and your external flash high enough, the external will over power the on board, and you won't even see it. But you need to set the on board high enough that the external will see it.
  5. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    Although there are only a few, that's one of the shortcomings with Nikon's CLS system. Being an IR system rather than a RF trigger, the bright sun can over power the signal between camera and flash.
    thenikonguy nearly had it with regard to the built-in flash. It's not a dimly lit trigger, it's a pre-flash to signal the flash. In TTL mode, the pre-flash communicates proper flash output based on the camera settings. Through the Commander mode, you can adjust the output of the built-in from full power to preflash only. I keep mine set on pre-flash only marked by (--) in the menu because I don't want it to contribute to the scene, only the off camera flashes.
    This assumes that the Commander mode of the D90 is the same as with the D300 & D700.
  6. hankejp
    hankejp TPF Noob!
    Aug 24, 2008
    608
    Wausau, Wisconsin
    Thank you for the replies. Yes, the pre-falsh is symboled by the --. Maybe I will try giving is as little power as needed for the 600 to flash.
d90 command flash turn off built in flash
d90 commander mode
d90 commander mode built in flash
d90 preflash
how di i turn off the built in flash in commander mode
how to set up external flash for d90
how to turn off flash d90
nikon d90 turn off flash
ways to shut off internal flash in nikon cameras
why does flash on nikon d90 keep flashing even on a sunny day
