D90 meterings
A lot depends on how you're lighting the subject, but generally spot or centre-weighted metering is best.
i use center weighted set to 6mm when i use my sb-600 with TTL,
if you shoot M then no need for meetering
Not true. If you are using flash with ttl, the TTL will meter based on what the camera is set. If it is set to matrix the TTL will meter differently than if it's set to center weighted. I know this for a fact because I struggled with my macro lighting...full manual with TTL....my problems were fixed by switching from center weighted to matrix metering.
you are right, whenever you are set on TTL, no matter wich meetering mode you are on, it will change flash output to expose correctly.
when i shoot manual, i also set the flash on manual :p, my bad
