D90 or any other Nikon question.
Discussion in 'Photography Beginners' Forum' started by TJ K, Dec 30, 2008.
  1. TJ K
    TJ K No longer a newbie, moving up!
    Sep 9, 2008
    2,093
    Sunny South Florida
    Ok so in the view finder it shows the exposure display but does it tell you if the photo is going to be over/under exposed or does it just show you the exposure you set? I was reading my manual and it says " the electronic analog exposure display in the viewfinder shows whether the photograph would be under- or over- exposed at current settings."
    Thank you to anyone who helps.
    -TJ
  2. TJ K
    Sep 9, 2008
    2,093
    Sunny South Florida
    Anyone?
  3. Kegger
    Kegger TPF Noob!
    Dec 30, 2007
    569
    The warm, sunny, very polite South
    That's what the meter on the bottom of the frame is for. Center in properly exposed, to the right is underexposed, and left is over exposed.
  4. Easy_Target
    Easy_Target TPF Noob!
    Aug 4, 2007
    380
    I don't know how it is on a D90, but on my D50, there's a center vertical bar with a bit of space on both sides then a + on one side and a - on the other. If you have bars between the middle and one of those, it's either over or under exposed. no bars, means it's a proper exposure according to the meter.
  5. Fishboy
    Fishboy TPF Noob!
    Jan 1, 2009
    49
    UK
    What the above 2 posts have described goes for my D80 too.
  6. Kendo
    Kendo TPF Noob!
    Nov 18, 2008
    87
    Marysville, CA
    I thought that if it was to the right it would be overexposed and to the left it would be underexposed. Is it like the histogram? Or is it opposite of what I said?
  7. dEARlEADER
    dEARlEADER TPF Noob!
    Apr 9, 2008
    1,312
    Canada
    I think Canon and Nikon viewfinder meters are reversed...
    Nikon uses the better format. Even Phil Canon (president of Canon) confessed this...
  8. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    "Phil Canon"? Who's that? President of Canon Worldwide is Tsuneji Uchida. President of Canon USA is Joe Adachi. President of Canon Canada is Kazuto "Kevin" Ogawa.
    Or were you making a joke?
  9. Kendo
    Kendo TPF Noob!
    Nov 18, 2008
    87
    Marysville, CA
    After looking this info on Google, you are right. So the bars are different for exposure.
  10. mrodgers
    mrodgers No longer a newbie, moving up!
    Dec 13, 2007
    1,662
    7
    Interesting on the difference between Canon and Nikon (and probably most others that would be like the Nikon).
    This is only in manual mode though, correct? In Av or Tv, that would be the exposure compensation? It is with mine (superzoom though, with EVF).
  11. kyrio
    kyrio TPF Noob!
    Dec 26, 2010
    nah
    on my d90, the exposure display is not 100% correct (However I do admit that white background might be a contributing factor)... is it my camera's issue?
  12. sleist
    sleist Been spending a lot of time on here!
    Nov 8, 2009
    3,560
    1,812
    Boston
    Just want to add that you will only see it constantly in M.
    In A or S, you will not see it if the camera is able to adjust shutter or aperture to achieve a proper exposure. If it can't, you will see the meter and it will blink along with the flash icon and ISO reading, indicating the ISO needs to be changed or flash activated to expose correctly.
    HTH
