Daily maintenance of smartphones
Link Delight Online Shop
Official Vendor
Supporting Vendor
Smart phones because of its fashion and powerful appearance, is favored by many consumers. But if you don't pay attention to maintenance or improper use , it is easy to shorten the life and even affect the normal use of the phone. In daily life, how should maintain a smart phone, the following provides two techniques for sharing.
Care for the mobile phone shell
In the life, often find some mobile phone shell scarred, the real reason in addition to normal wear and tear, is mainly caused by the fall, knock, or shake. Connectors inside the phone will vibrate loose, even desoldering components, wiring loose. Don't pay attention to protect mobile phone shell, the injured is not only a mobile phone's appearance, also can damage the phone core (internal circuit).
Add a protective cover case for mobile phones and transparent silicone set is preferred, it does not affect the appearance, and also has a strong protective effect, even in a year or two mobile phones, still as good as new. More than a layer of protective sleeve is tantamount to add a coat for the cell phone, one is able to reduce mobile phone shell wear, and second is the ability to reduce the damage to the phone when dropped or water.
Protect the charging port or USB port, some phones have a special rubber protective cover, this is because these sites charge if excessive oxidation or after contact with certain metals on the phone, the signal has a great influence, so keep these two interfaces cleaning.
Most of the time, mobile phone screen and buttons are easy to be excessive wear. Android cell phones more are touch screen machine, button is less, and inappropriate habits, ordinary screen protector I'm afraid after a few days will be scarred. And we are in the process of using, in order to avoid excessive wear in the screen or keyboard, we should pay attention to the length of the nails, long nails the greater lethality.
Pay attention to the use of the environment
Let the phone away from magnets environment. Mobile phone speaker itself has a magnetic, much in the environment of iron powder, mobile phone speakers sound hole may inhaling too much iron, along with the film on the horn, and cause the smaller voice even can't hear. So don't make the phone more often contact iron powder.
Cell Phone is afraid of hot and cold, don't put mobile phones in a very hot place, many users working in the office, their phones behind a glass wall at the direct sunlight, and some on the radiator, fireside. Mobile phone within tight layout of electronic components, itself bad heat dissipation, high temperature will shorten the life and damage battery and certain plastic deformation or melting. Also we can't keep phones in very cold places, when the phone gets hot (to its normal temperature), because of the cold, mobile phone within may form moisture, it will damage electronic circuit boards. In the same way, when you are in a cool room to hot on the street, don't take the phone out immediately, you should allow it to gradually adapt to the surrounding environment of temperature change.
