Dark corners on rear LCD of Nikon D7000
Discussion in 'Nikon Cameras' started by Iftekhar Ahmed, Apr 11, 2016.
  1. Iftekhar Ahmed
    Iftekhar Ahmed TPF Noob!
    Apr 11, 2016
    Hello all. I have just signed-up in this forum. I am in need of your help. I have a Nikon D7000 and I have been using it since 2012. Everything was working fine. Suddenly yesterday, I saw that the rear LCD is showing some dark shadows. All four corners have this dark shadow but the shadows on upper and lower corners on the right side of the LCD is bigger. First I thought it's a lens issue then I changed lens and its the same. Live view is pretty alarming with these corner patches. Although my images are not effected by this dark shadow, I am in need of your help or suggestions on what could be the reason behind this problem and is there any way to solve this. If anyone faced the same issue earlier, it will be really helpful if you share your experience.
    Sorry for my long words. Thanks a lot for your time.
  2. astroNikon
    astroNikon 'ya all Bananas I tell 'ya Supporting Member
    Aug 15, 2013
    13,358
    3,241
    SE Michigan
    I had a d7000 but never had the issues you are describing.
    Is there any separation of the LCD panel at the corners in the areas of the dark shadows?
    This may be an instance where there is a LCD issue, which would need to be sent to Nikon to fix.
  3. Iftekhar Ahmed
    Apr 11, 2016
    Hello astroNikon. No there is no separation. And there is no signs of damage too..Wondering how this happened.
    I'll wait for any other tips/suggestion until I take it to the service center. Thank you for your reply.
  4. goooner
    goooner Been spending a lot of time on here!
    Oct 4, 2014
    2,222
    977
    Was it exposed to direct sunlight for a while? It should go back to normal if it was not left in direct sunlight for too long.
  5. Iftekhar Ahmed
    Apr 11, 2016
    Actually it was bagged for a certain period!
    Good one. I will give it a try first thing in the morning. Thanks a lot!
  6. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,730
    8,134
    Iowa
    See if you can post of photo of it with the issue you describe. That will go a long way towards helping out.
  7. Manomanoj
    Manomanoj TPF Noob!
    Apr 22, 2016
    Hello all.
    I am also having the same problem.
    I have a Nikon D7000 I saw that the rear LCD is showing some dark shadows. All four corners have this dark shadow but the shadows on upper and lower corners on the right side of the LCD is bigger. First I thought it's a lens issue then I changed lens and its the same. Live view is pretty alarming with these corner patches. Although my images are not effected by this dark shadow, I am in need of your help or suggestions on what could be the reason behind this problem and is there any way to solve this. If anyone faced the same issue earlier, it will be really helpful if you share your experience.
    Any solution??
    Iftekhar Ahmed Have you tried anything, now the problem resolved or not ?
  8. Manomanoj
    Manomanoj TPF Noob!
    Apr 22, 2016
d7000 lcd dark at the corner
dark corner lcd d7000
dark corners on the rear lcd of my canon 600d
dslr lcd dark corners
lcd canon camera dark corner
nikon d3000 dark lcd corners
nikon d3000 screen side black
nikon lcd dark corner
nikon lcd edge dark
