dark enough?
Discussion in 'The Darkroom' started by denada, Aug 1, 2016.
  1. denada
    denada No longer a newbie, moving up!
    Feb 22, 2016
    193
    88
    i feel like i can see stuff in my darkroom with the safelight off. this makes no sense to me. it is a cement room with a small window and a door. the door is caulked, weatherstripped, and whatever that rubber thing that goes across the bottom is called. two pieces of duct tape over the keyhole. the window is sealed from the inside with tinfoil and cardboard and from the outside with a vinyl board. during the day and with lights in the adjacent room turned on, there is not a pinhole of light to be seen. even after waiting 15 minutes in the dark.
    tonight i used it to change film for the first time. loading 4x5 holders. in addition to it being dark outside, i turned off the lights outside the darkroom. i cannot fathom how there could be any light getting into the room. still, i am almost 100 percent sure i can see my hand waving in front of my face. even if i close my eyes tight. is this my mind messing with me? i will find out when i develop later this week if am truly light tight, but i am curious if this is a common phenomenon?
    thanks!
  2. Dave442
    Dave442 No longer a newbie, moving up!
    Feb 1, 2015
    1,681
    386
    I think it just means you have spent too much time in the darkroom.
    You can just check by putting out a bit of film and cover part with a coin, let it sit then develop and see if there is any marking. Look around the ceiling area as well, often these are not made to lightroom standards unless that spec was in the initial room design.
    • Agree Agree x 5
    • Like Like x 1
  3. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,550
    8,088
    Iowa
    Take someone else into the darkroom and tell them to hold up their hand and ask you, "How many fingers am I holding up?" You'll get it wrong if you truly cannot see.
  4. KenC
    KenC Been spending a lot of time on here!
    Jan 18, 2010
    5,700
    1,472
    Philadelphia
    It's just your brain trying to keep busy. If you had a light leak you would be able to see something in the area where the leak is. If you allow your eyes to adjust for at least a couple of minutes and then face in the direction of the doors, windows, etc. and you can't say for sure that you see something, you're good.
    • Agree Agree x 3
  5. jcdeboever
    jcdeboever TPF Supporters Supporting Member
    Sep 5, 2015
    13,682
    7,152
    Michigan
    Couldn't Wonder Woman see in the dark?
    • Funny Funny x 1
  6. 480sparky
    Mar 8, 2011
    22,550
    8,088
    Iowa
    That being true, you'd also see the light leak itself.............. shining like a 100,000-watt light bulb.
    • Agree Agree x 1
  7. Gary A.
    Gary A. Been spending a lot of time on here!
    Sep 17, 2014
    18,687
    5,971
    Southern California
    Yeah, it's just your brain messing with you. To set your mind at ease, follow Dave's advice and set some film and/or paper out and partially cover part of it.
    • Agree Agree x 1
  8. denada
    Feb 22, 2016
    193
    88
    alright. that's what i was hoping. next time i'm developing i'll do the coin check just so i can quit doubting myself. i appreciate all the replies.
  9. compur
    compur No longer a newbie, moving up!
    Mar 6, 2008
    2,972
    491
    L.A.
    Seeing without light is a known phenomena. I have experienced this too. Explanations vary.
    But, as noted by others above, if there were a light leak in your darkroom (the type that can affect your materials) you should be able to see the leak itself as a glow or point of light, etc.
    • Like Like x 1
  10. smoke665
    smoke665 TPF Supporters Supporting Member
    Mar 29, 2016
    4,742
    1,908
    Alabama
    This brought back memories of those nights before press day, still being in the darkroom at 1 am hoping I was going to get done before daylight. I can remember that weird sensation that I could actually see in the dark.
  11. edma
    edma TPF Noob!
    Aug 25, 2016
    Happened to me and drove me nuts while putting film onto spools. Now I just spend the first minute allowing my eyes to adjust and look around for leaks. If no leak is forthcoming, I just spend the rest of the time with my eyes closed. Feels weird to work in total darkness and peer into the void anyway:)
    • Like Like x 1
  12. webestang64
    webestang64 No longer a newbie, moving up!
    May 15, 2013
    972
    448
    St. Louis, MO. USA
    That used to happen to me all the time when printing RA4 prints at work. I knew for a fact the room was totally dark but could still see almost everything in the room. It's a creepy feeling.
