Dark to Light Photo
Discussion in 'Photography Beginners' Forum' started by ABPASnapshot, Sep 6, 2008.
  1. ABPASnapshot
    ABPASnapshot TPF Noob!
    Aug 26, 2008
    19
    Hi folks - recently I was inside a house that was open to the outside where it was very bright - the photos were too dark relative to the inside of the house, there were no details visible - what is the trick to getting some detail of the inside (not underexposed) while not overexposing the outside?:thumbup:
  2. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    Flash, lotsa flash.
  3. iPwnF00lz
    iPwnF00lz TPF Noob!
    Aug 24, 2008
    81
    Oswego/Ithaca/ElmiraNY
    Raising your iso, photoshop and adjust brightness.
  4. rubbertree
    rubbertree TPF Noob!
    Sep 7, 2007
    727
    Canada
    but don't you find when you adjust the brightness in pp that it brings out a lot of grain in the dark areas?
  5. iPwnF00lz
    iPwnF00lz TPF Noob!
    Aug 24, 2008
    81
    Yep but sometimes it isn't that bad if you don't over adjust it.
  6. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    That's not going to work.
    The problem isn't the ability to expose the interior at all, the problem is the differential between the light outside and the light inside. Our cameras do not have the same dynamic range of light sensitivity as the human eye, so to expose the inside, the outside gets washed out... to expose the outside, the inside dark (or black).
    A flash can and will help with this... but it can take quite a bit of light inside to counteract the outside, depending on circumstances.
    Your options are:
    - Flash
    - Create a composite image from multiple exposures
    - HDR (a sort of automated composite image)
    - Invent better photographic technologies
  7. ABPASnapshot
    Aug 26, 2008
    19
