Darking and redness when saved for web?
Discussion in 'Beyond the Basics' started by elsaspet, Jul 13, 2005.
  1. elsaspet
    elsaspet TPF Noob!
    Dec 14, 2004
    4,054
    37
    Dallas
    I notice that when I save for web in CS2, the images become darker and redder for some reason. I didn't have this problem with regular CS. Is anyone else having this problem? How do I correct it?
  2. vonDrehle
    vonDrehle TPF Noob!
    Jun 27, 2005
    430
    6
    North Carolina
    A month or two ago I had a problem with my colors being completely different in photoshop then when I saved them.
    This is what I got when I made something black and white. (When I put saturation on -100)
    [​IMG]
    The saved file would be normal black and white
    To fix it I went to
    Edit > Color Settings > Color Management Off
    But I don't know if you are having the exact same problem I was.
  3. foxXx
    foxXx TPF Noob!
    Jul 13, 2005
    22
    Ontario
    I wouldn't recommend turning off colour managment. What I do and it works very nicely is in CS2 go to EDIT>CONVERT TO PROFILE>sRGB. sRGB is the setting for the web, after you do all of this save for the web, right click on your image and make sure the option called something like maintain or use colour profile is selected. If you do all of these steps correct your image will look exactly the same in PS as the web, good luck :)
  4. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    I find that my images are lightened by 'Save for web'
  5. SLOShooter
    SLOShooter TPF Noob!
    Dec 21, 2004
    421
    Your probably working color space A and saving in color space B which is causing the color shift. Check out which one you using to edit and which one your using to save.
  6. elsaspet
    elsaspet TPF Noob!
    Dec 14, 2004
    4,054
    37
    Dallas
    Thanks guys!
    Yours are lighter Mike? Damn, that's weird...
    Slo Shooter, where do I find this A and B thing?
  7. elsaspet
    elsaspet TPF Noob!
    Dec 14, 2004
    4,054
    37
    Dallas
    Thanks guys!
    Slo Shooter, where do I find this A and B thing? Or does that only apply to Mike's lightening problem?
  8. SLOShooter
    Dec 21, 2004
    421
    Well I was merely using A and B as variables like X and Y.
    The colorspace is usually determined when you create a new document. If you hit new you'll see an option for choosing your color mode. Alternativly if your creating documents from the RAW converter it will be under workflow options.
    If you want to see what a current file is or want to convert a file to a different color space hit Edit/Convert to Profile...
    At the top you will see the current profile and then a drop down box of choices. As FoxXx mentioned above you can convert the file to sRGB, which is what monitors use and then you shouldn't notice a difference when you Save as Web.
  9. elsaspet
    elsaspet TPF Noob!
    Dec 14, 2004
    4,054
    37
    Dallas
    Uhoh. I can see that I am going to have to read the book...:meh:
