Dented filter mounting threads on good lens
Discussion in 'Beyond the Basics' started by JonK, Mar 5, 2006.
  1. JonK
    JonK I want MORE!!
    May 19, 2005
    3,568
    140
    Manitoba, Canada
    I just bought a Asahi Pentax spotmatic 35mm with a 50mm F1.4 super-takumar lens. This lens is supposedly very good but the filter ring thread area is dented in and it's not possible to mount a filter.
    Is there any safe, easy method of straightening it out?
    I'll try to post a pic later if that helps.
  2. DestinDave
    DestinDave Master of Non Sequitur
    Jan 29, 2006
    480
    Not where I thought I'd end up
    Jon... is it dented at the very end? If so, maybe you could carefully work it with a pair of pliers. Other than that I'd be afraid to try anything... Post a pic though if you get a chance...
    Dave
  3. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,777
    50
    Ahwatukee, AZ
    Try this:
    http://www.kyphoto.com/classics/filterringtool.html
  4. darich
    darich No longer a newbie, moving up!
    Jan 22, 2005
    1,230
    Near Lanark, Scotland
    I dented the ring of my 24-70 f2.8 L lens. I was distrught because i thought it was for the bin - thankfully the glass was fine.
    I used a local Canon approved repair and service centre - they straightened it out for around £23.
    I did have to buy a new polarizer though - i had damaged the thread for that too.
    Try your local repair shop.
  5. JonK
    JonK I want MORE!!
    May 19, 2005
    3,568
    140
    Manitoba, Canada
    Thanks for the suggestions and advice. :D will give it a go mitica. if not...mebbe take it in for a quote.
