depth of field
Discussion in 'Beyond the Basics' started by khushi2004, Apr 18, 2004.
  1. khushi2004
    khushi2004 TPF Noob!
    Mar 12, 2004
    28
    Hi i hv Canon AV 1 camera, aperture priority try to test some DOF shots using iso 400.
    I hv just clue that using higher and lower aperture like 2.8 and 16 i will get higher and lower DOF, if i use f2.8 i do i get my subject sharp and background blurred?
    my subject may be person and background might be trees and houses.
    what changes i can see when i change my aperture to f/22 to same subject ?
    Can u more explain me about DOF?
    regards
  2. Goofup
    Goofup TPF Noob!
    Feb 21, 2004
    141
    Middle of Oklahoma
    The short answers to your questions are: at F2.8 the houses probably will be fuzzy, at F16 they'll probably be sharp- but that depends on how close or far away the subject is that you're focusing on and how far away the houses are from the subject.
    Maybe you can get a handle on DOF by reading this:
    http://www.megapixel.net/html/issueindex.php?lang=en
    As to what will happen if a scene like you're describing is shot at f2.8 and F22, try it- then you can actually see for yourself what happens.
  3. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
