Developing film
Discussion in 'Film Discussion and Q & A' started by Shrimpy, Aug 3, 2008.
  1. Shrimpy
    Shrimpy TPF Noob!
    Jul 28, 2008
    36
    I'm a bit, well actually very confused about the process of developing film at home. It's something I'd like to try, but I'm having trouble understanding the whole process. I've read up on the actual process of developing the negatives, but how do you turn the negatives into full sized pictures?
    If somebody could direct me towards a detailed guide for B&W developing and Color, it would be greatly appreciated :D
  2. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,898
    11
    Arizona
    Basically, an enlarger is a type of projector which projects the image from the negative onto sensitized paper (along the lines of a slide projector). You then develop the paper. :)
    http://en.wikipedia.org/wiki/Enlarger
    Some people get their negatives digitally scanned and then print them on a digital printer.
  3. Shrimpy
    Shrimpy TPF Noob!
    Jul 28, 2008
    36
    Thanks for the reply!
    So the enlarger basically makes a giant negative, which you then submerge in the chemical bath?
  4. tkaat
    tkaat TPF Noob!
    May 27, 2008
    307
    On a Island
    I would think that in the long run it would be cheaper for you to purchase a negative scanner and a good/great printer
  5. Shrimpy
    Shrimpy TPF Noob!
    Jul 28, 2008
    36
    So I'm assuming the negative scanner automatically converts it into color or B&W?
    And also is the process the same for both B&W film and color film, aside from chemicals used?
    Sorry for all the questions! :lol:
  6. icassell
    Jun 7, 2008
    9,898
    11
    Arizona
    Well, the enlarger inverts the image -- turning the negative into a positive on photosensitive paper -- which you then put in the chemical bath.
  7. icassell
    Jun 7, 2008
    9,898
    11
    Arizona
    Cheaper, maybe (although a high-quality negative scanner can be quite pricey), but some people really enjoy the darkroom side of photography. I certainly do, but have no place or time to do it anymore. At least with photoshop, I can sit socially with my family as I work.
  8. Shrimpy
    Shrimpy TPF Noob!
    Jul 28, 2008
    36
    Is there a noticeable difference in quality between the enlarger method vs. the scanner method?
  9. icassell
    Jun 7, 2008
    9,898
    11
    Arizona
    I better leave this one to the more erudite among us ...
  10. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    Not really. Processes are similar for colour and B&W but are done at very different temperatures. B&W films are usually developed around 20 celsius whereas developing colour is done at higher temperature. Temperature control is critical (even more so for colour) so it is quite difficult to maintain higher temperatures required for colour films without special equipment. Developing a B&W film is fairly straight forward. Here is an example of how it is done (Google for other links).
  11. tkaat
    tkaat TPF Noob!
    May 27, 2008
    307
    On a Island
    I personally don't develop my own film but have a friend that does and he uses a film scanner.
    It comes with some software to help you
    I'm not to sure if you tell the software that comes with it that the picture is a B&W or color negative
    depending on the scanner you could also process 120 film
    If you want to understand a little more about the scanners I found this website helpful
    http://www.scantips.com/basics13.html
  12. Steph
    Oct 18, 2006
    1,314
    I think you can achieve great results with both methods. Many people think that a B&W scanned negative printed with a printer does not have the same quality as a well printed silver image ('enlarger method'). Moreover, I am not so sure that the scanner/printer method would be cheaper than the enlarger method. To achieve good results with a scanner, you need a good scanner, probably a calibrated monitor and a good printer (consumable such as inks and paper are not that cheap). On the other hand enlargers are dirt cheap at the moment (have a look on eBay).
