Difference between 55-200mm lens and 70-200mm lens
Discussion in 'Photography Equipment & Products' started by tinkerbell50404, Jul 14, 2006.
  1. tinkerbell50404
    tinkerbell50404 TPF Noob!
    Jul 5, 2006
    27
    Can you guys tell me what the difference is between a 55-200mm lens and a 70-200mm lens?
    Since they are both 200mm, what is the significance of the first number?
  2. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    Both are zoom lenses. You can change your focal length (zoom in and out).
    55-700 - This lens covers focal lengths from 55mm to 200mm.
    70-200 - This takes care of focal lengths from 70mm-200mm.
  3. tinkerbell50404
    Jul 5, 2006
    27
    so if they both go up to 200mm wouldn't the 55-200 be better, since you would be able to cover more focal lengths?
    Confuses me even more, because the 70-200mm is much more money. I would think it would be less since it offers less focal lengths than the 55-200
  4. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    The 55-200 may be more convenient but when lens makers design a lens with such a wide range...they have to make compromises and the image quality suffers. Typically you will find the best image quality for the price come from prime lenses that do not zoom at all.
    Also, each lens has a maximum aperture. That is the adjustable (in most cases) hole in the lens that lets light though. The bigger the aperture, the more light can get though. But to make the aperture bigger, the lens has to be made bigger with more glass etc. The maximum aperture is also listed in the name of a lens. For example, you can buy a 70-200 F4. (70-200 being the 'zoom' range and F4 being the biggest aperture) (smaller F numbers mean bigger aperture). Or you could buy a 70-200 F2.8. The F2.8 version will be twice as expensive because it has a bigger aperture and is therefore a bigger lens.
    Most zoom lenses will have a range of maximum aperture. For example the 55-200 is [f/4-5.6] This means that when you are at 55mm, the maximum aperture is F4 but when zoomed out to 200 the maximum aperture is only F5.6
    Also, some lenses are just better than others. There are many different ways to measure the quality of a lens...it can often be hard to figure out which one is best. Typically, the best way to quickly measure quality is to look at the price. You get what you pay for and better lenses cost more money. That being said...the words Canon & Nikon on a lens will often mean it's more expensive. Brands like Sigma and Tamron may sometimes be more economical...although the best lenses for these cameras will probably come from Nikon or Canon.
    Do some reading. Look up things like Aperture, shutter speed, exposure etc. Once you have a better understanding of photography...picking a lens will become easier.
  5. tinkerbell50404
    Jul 5, 2006
    27
    wow that was very imformative, I understand it a lot better now.
    Thanks so much!
55-200mm vs 70-200mm
70-200mm or 55-200mm
difference between 55-200 and 70-200
difference between 55-200mm and 70-200mm
dofference between 55-250 mm lens and 70-200
how to explain the difference between a 55-200 and a 70-200 lens
nikon 70-200 f4 vs 55-200
what is the difference between 55-200mm and 70-200mm lens
whats the difference between a 70-200mm lens and a 55-200 lens?
which is better between 55 200mm
