Difference between EF and EF-S lenses?
Discussion in 'Photography Beginners' Forum' started by aarhap, Feb 29, 2008.
  1. aarhap
    aarhap TPF Noob!
    Jan 9, 2008
    19
    New Zealand
    What are the differences? I have an EF-S 18-55mm and it seems rather flimsy and low quality compared to the 30-80mm EF lens I have, but thats the only difference I could find...
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    EF lenses are originally designed for 35mm film cameras. Their image circle (image projected into the camera) is big enough to cover 35mm film or a full frame digital sensor (as in the 5D or 1Ds).
    Cameras like yours, have a smaller sensor, which is OK but it only sees the middle section of the image circle...'cropping' the edges off. This makes it hard to get a wide angle view.
    For this reason, Canon made EF-S lenses. They are designed only for cameras with sensors smaller than full frame. Their image circle isn't as big and their rear element sticks into the camera a bit farther than EF lenses. Basically, they are a cheaper & smaller way to get wider views on crop cameras.
    So EF lenses can be used on any EOS camera, film or digital. EF-S lenses must be used on 'crop' bodies only.
    Build quality isn't part of it. Sure, your EF-S 18-55mm lens feels like a toy...but there are plenty of EF lenses that are just as bad. There are EF-S lenses that are much, much better (well most of them are better than the 18-55mm).
  3. aarhap
    aarhap TPF Noob!
    Jan 9, 2008
    19
    New Zealand
    Ahhh right, it all makes sense now. Thanks for that :D
difference between ef and ef-s lenses
picture difference between canon ef and ef-s lenses
