Difference in Polarizer filters
Discussion in 'Digital Discussion & Q&A' started by HoboSyke, Sep 24, 2008.
  1. HoboSyke
    HoboSyke TPF Noob!
    Jun 8, 2005
    1,052
    7
    Sydney - Australia
    Hi all, just wondering what is the difference in these polarizer filters?
    Hoya Standard Circular Polarising Filter - 77mm which is AU$88 and the Hoya Pro1D Circular Polarising Filter - 77mm which is AU$239 ????
    Thanks..
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    I do not know much about Hoya, but maybe the coatings?
    Also there are different ways to construct a polariser.
  3. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    A Mercedes 4 door sedan is $50,000 and a Kia 4 door sedan is $20,000. :er:
  4. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    Cars are so incredibly cheap over there ...
  5. tpimages
    tpimages TPF Noob!
    Sep 7, 2008
    14
    the glass and the coating. The objective is to have minimal glass between you and your subject, so why add crappy glass? Mind you if you aren't using pro series lenses you probably won't notice the difference.
  6. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    It amazes me how many pros and serious amateurs will pay an extra $150 to $200 for fancy multicoatings, but can't be bothered to use their lens hood, which probably increases image quality more.
  7. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    I am sorry, but a polariser does things completely different from a lens hood. hence the two cannot be compared.
    IF I use a polariser, I do want to minimise stray reflections, in particular those coming from lights sources in the scene/frame, and I want a tough easy to clean filter surface, and both require good coatings, not a lens hood.
  8. HoboSyke
    HoboSyke TPF Noob!
    Jun 8, 2005
    1,052
    7
    Sydney - Australia
    Thanks guys, well im shooting with L lenses on the canon system. And I already use hoya pro1 UV filters. So i'll just get the more expensive one I guess..
  9. Bifurcator
    Bifurcator TPF Noob!
    Jun 1, 2008
    3,312
    Japan
    I wonder if what K.S. Matt Fish meant was that the differences are probably only to do with flare, scatter, and internal reflections - most of which a lens-hood will also very often prevent?
    And that does happen to be true. Besides the actual flare elements however, almost all flare and scatter can be removed in post very simply and without any observable degradation to the image quality. In fact almost all of it is removed just by the typical Levels and Brightness/Contrast adjustments that most of us do to almost every image anyway.
    There may be some differences - indeed I believe there are but I would never pay over $100 for a polarizer and I would be questioning my own sanity at anything much or $50.00 even if I were this ultra-pro who got $5,000 a shot just for being the one to press the shutter and had all the highest grade lenses available at any price.
  10. Bifurcator
    Jun 1, 2008
    3,312
    Japan
    Also Hoya (whos glass I've been told on many many occasions is identical to and made by Kenko) is always like 2 and 3 times the price of Kenko brand filters.
    Hoya AC #4 CloseUp Filter $190
    Kenko AC #4 CloseUp Filter $24
    Reselts == IDENTICAL,
    Construction == IDENTICAL,
    Even the printing is identical except for the letters "HOYA" instead of "Kenko".
    Hoya Pro 1D Circular Polarizer $240
    Kenko Pro 1D Circular Polarizer $60
    Construction == Identical
    Results == Identical (assumed)
  11. Bifurcator
    Jun 1, 2008
    3,312
    Japan
  12. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    Isn't it more likely that Hoya make the glass for Kenko?
    Best,
    Helen
