Difference??
Discussion in 'Photography Beginners' Forum' started by kdabbagh, Jan 9, 2008.
  1. kdabbagh
    kdabbagh TPF Noob!
    Dec 31, 2007
    148
    Cairo
    I am looking around for a a Nikkor AF 50mm lens...
    I found two
    1. Nikkor AF 50mm f/1.4D found here--> http://www.vistek.ca/details/details.aspx?t=specs&WebCode=133733&CategoryID=CameraLenses
    2. Nikkor AF 50mm f/1.8D found here -->
    http://www.vistek.ca/details/details.aspx?t=specs&WebCode=205641&CategoryID=CameraLenses
    The latter is cheaper than the former by $200...what accounts for this price difference? Is it that the first one has a slightly higher aperture?
    I want this for my D40x mostly for landscape and portrait shots because I heard from a lot of people it delivers good quality and vivid colours..
    any advice would be helpful...thank you
  2. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    The 1.4 is 2/3rds of a stop faster which can make a big difference in night time photography, the bokeh is much much nicer than the 1.8 version which makes it better for portraits, and the depth of field you can get with the 1.4 is even tighter than the 1.8 which gives you more artistic freedom. The 1.8 version is "generally" considrered to be a bit sharper. I have the 1.8 version and it's the sharpest and contrastiest lens that I own easily. For a D40x, I think the 1.4 version would be a little overkill, and it'll be tough to manually focus reliably at any aperture larger than f/2.8 on a D40 w/o a different focusing screen. I'm going on vacation here in a couple of weeks, but after I get back I think I'm going to order a Katz Eye screen for my 40.
  3. kdabbagh
    kdabbagh TPF Noob!
    Dec 31, 2007
    148
    Cairo
    hmm....so the 1.8 version would be good enough for my d40x...? I am still a beginner in the DSLR world and I just need a contrasty lens for doing some portrait and fashion shoots...I can't believe tho there's a 200$ difference...its insane
    I checked out those Kats Eye Screens....how do they work exactly?
  4. CJL
    CJL TPF Noob!
    Jan 8, 2008
    27
    MA
    I have the 1.8 and it works great. I think you will be happy with it. I cant give a comparison since I have not used the 1.4 but I am happy with my 1.8.
  5. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    1.8 is way cheaper, because it's designed to be cheap. It's one of the first lenses every Nikon or Canon owner picks up...
    Great quality lens, and fast enough for plenty of good stuff.
  6. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    Good quality glass/image, marginal quality build.
  7. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    It's easier to just try out an old film body at a local camera shop that carries used stuff than to explain. Old 35mm film bodies had much larger and brighter viewfinders along with a split prism (the circley thing in the middle) that helps you see detail at your focus point a lot better to help you see in focus or out of focus, and it'll also show differences at f/2.8 and larger apertures whereas the tiny little digital viewfinders don't. It doesn't affect autofocusing or metering at all so it's just a drop in replacement.
  8. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    I don't normally use my 50 mm f/1.4 AF on my D40x, so I gave it a try to see how difficult it was to focus at f/1.4. I used the electronic rangefinder, and the split prism of the K3 screen I have modified to fit the D40x (the Katz Eye screens appear to be cut-down $30 Nikon K3 screens). I could focus more accurately with the split prism than with the electronic rangefinder. The electronic rangefinder was good enough for f/2, the split prism for f/1.4.
    I have calibrated both the AF and the viewfinder of my D40x, by the way. Normally I use the manual focus f/1.2 when I use a 50 mm on the D40x. There is no metering of course, because the lens has no CPU. The AF lenses will meter with the D40x, they just won't autofocus.
    The 50 is a bit long for my taste for landscapes. I prefer a 24 mm or 28 mm on the DX-size sensor.
    Best,
    Helen
  9. kdabbagh
    kdabbagh TPF Noob!
    Dec 31, 2007
    148
    Cairo
    So both the 1.4 and 1.8 don't auto focus? since i am a noob, i didnt understand the latter part of your post regarding rangefiners, prisms, and screens...but what i understood is that to fix the manual focus problem u need to buy some sort of screen..and that the katz eyes r just as good as nikons? right?
    :blushing:
  10. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    The D40x will only autofocus with Nikon AF-S and Sigma HSM lenses. If you attach a plain Nikon AF lens, the D40x exposure meter will work, but you will not have autofocus. This is because the AF-S lenses have the motor in the lens, the AF lenses are driven by the body. The D40/D40x has not motor in the body.
    The two 50 mm autofocus Nikon lenses are only AF, not AF-S, so they can only be used as manual focus lenses with the D40 and D40x. In manual focus you will have the 'electronic rangefinder' - which is the green dot on the lower left of the screen that shows when you are in focus.
    The Katz Eye screens are $30 Nikon screens that are made by Nikon for a Nikon film camera, cut down to fit the smaller viewfinder area.
    Is it becoming any clearer? This stuff is so much easier to explain face-to-face.
    Best,
    Helen
  11. kdabbagh
    kdabbagh TPF Noob!
    Dec 31, 2007
    148
    Cairo
    Thanks Helen, yes much clearer.
    Is there a specific model of the Katz Eyes Screens I should look for for my d40x? If you have a link that would be great.....thanks :)
  12. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
