diffuser/bounce card questions
Discussion in 'Photography Equipment & Products' started by Deadeye008, Oct 9, 2007.
  1. Deadeye008
    Deadeye008 TPF Noob!
    Apr 24, 2007
    532
    Utah
    I am awaiting my new Canon 430EX flash and was looking at different diffusers and bounce cards. What is the difference between a lambency diffuser and a bounce card? What are the different colored domes for on the lambency diffuser? Here are the two that I am looking at.
    Thanks
    http://cgi.ebay.com/Flash-Bounce-Ca...ryZ15221QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    http://cgi.ebay.com/Lambency-Flash-...ryZ15221QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  2. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    What's wrong with a piece of card and an elastic band?
  3. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I suggest that you first learn to use your flash without any 'trinkets'.
  4. Deadeye008
    Apr 24, 2007
    532
    Utah
    I plan on fully learning how to use my flash when it gets here. I have just seen some write-ups about how much better pictures can turn out if you use a bounce card or diffuser and thought I would get some answers from those who have used them. Thanks
  5. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Pictures are much better when the light source is directional and larger. All that is needed for this is a large wall or ceiling, and this is free. Save your money. This why you bought a flash with a tilt and swivel "bounce" head.
  6. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Matt is right.
    Flash diffusers and bounce accesories can serve a purpose and help to make our photos better...but I don't think there is any one that is best for all situations and many of them are good for some things and terrible for others.
    As mentioned, a card and an elastic band can do the job that most accesories try to do.
  7. oldnavy170
    oldnavy170 TPF Noob!
    Sep 7, 2006
    2,236
    Rochester, New York
    A diffuser is used outdoors when you direct the flash right at your subject. By using a diffuser you make the light look softer, especially on people. (They might be used other ways too but this is the only way that I use mine)
  8. Deadeye008
    Apr 24, 2007
    532
    Utah
    Thanks all, for the information. I can't wait to get my new flash and play around with it. I've been using a Bower flash for the last few months and it is ok but not very consistent. I'm looking forward to what this new one will do. Thanks again.
  9. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    One thing you should note is that no two are alike. The SB-800 includes a small one. But I added a strip of velcro and cut up 2 differently sized and shaped flash cards. Each of the 3 gives a different effect. Some people say that the Omnisphere is better than the Gary Phong diffuser I say that is a load of rubbish they are different just like an umbrella is different from a softbox, or a silver umbrella is different from a white one.
    I suggest you play around with bits of paper and some elastic. Make papers which let light bounce to the roof, make ones which don't and instead just create a bigger light source. Use them backwards, play compare and then go out and start actually spending money once you find out how the subtleties change. Only then will you get good results out of them.
  10. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    It is true that a diffuser will soften the light...if it enlarges the light source...which many of these accesories don't do....especially outdoors (nothing to bounce off of).
    I have found that when shooting outdoors, you need all the flash power you can get...and most all of these accesories actually rob power...so it's counter productive to use them outdoors. Also, typically when shooting outdoors, the flash is for fill only, so it's not as important that it be 'soft' light.
    When shooting indoors and using the flash as the main light, on the other hand...softer light makes much more of a difference. Indoors, this can often be accomplished by bouncing the light, which is what most accesories help with.
  11. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    That second diffuser listed always reminds me of those deli containers I by potato salad in. Thats pretty much all that it is actually.;)
  12. Mike_E
    Jan 26, 2007
    5,327
    266
    Hey Deadeye008, Do you have a $5 bill? And maybe an hour?
    Try this, the foam one- at the bottom...
    http://super.nova.org/DPR/DIY01/
