Diffuser or Omni-bounce?
Discussion in 'Photography Beginners' Forum' started by anubis404, Dec 7, 2008.
  1. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    I have an SB-600 and am looking for something that will make the light softer and more natural. What does a diffuser do that an omni-bounce doesn't? I don't want to spend too much money, but I'm not sure what to get. Help would be appreciated.
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    'Diffuser' is a pretty general term. What are you talking about exactly?
    The Omni-bounce is meant to be used when you are bouncing the flash (off of the ceiling for example). It sends some of the light forward to fill in shadows that might be caused by the light that is being bounced. It also spreads it out in other directions, with the hope that it might bounce and come back.
    A lot of people mistakenly believe that just putting something like this on the flash will soften the light by itself. To make a light softer, you can either increase the size of the source or move it closer to the subject. Sure, the Omni-bounce increases the size of the flash head, but only by a little bit....and it's not really any closer...so it won't really make the light softer. But it will rob you of some light.
    The easiest way to make your flashed light softer, is to bounce it. Your 'light source' essentially becomes the surface that you are bouncing off of, which will probably be a lot larger than the flash head. In normal sized rooms, you can even point the flash up and behind you (try it).
    Most flash accessories are made to help you, while you are already bouncing the light. A simple bounce card costs next to nothing and does basically the same thing.
  3. rlcphotos
    rlcphotos TPF Noob!
    Nov 23, 2007
    197
    Western Pa.
    cut the top off of a rubbing alcohol bottles really cheap, slip over the top of the flash:mrgreen:
