diffusion panel
Discussion in 'General Shop Talk' started by JimmyJaceyMom, Feb 10, 2008.
  1. JimmyJaceyMom
    JimmyJaceyMom TPF Noob!
    Nov 27, 2006
    1,768
    PA
  2. MichaelT
    MichaelT TPF Noob!
    Jan 18, 2008
    95
    Washington State
    I made two out of pvc. One is handheld by an assistant, just a 4x4 square with 4' handles, just to shade outdoor subjects from the direct sunlight when I'm out on location. The other is in my garden and is self standing and goes up and over the subject. I live in a desert and they really open up the possibilities in areas that would otherwise not work.
  3. JimmyJaceyMom
    Nov 27, 2006
    1,768
    PA
    Oh wow yes i can imagine that it is helpful for you - cool thanks for the reply ;)
  4. mrkz1974
    mrkz1974 TPF Noob!
    Apr 10, 2008
    4
  5. AprilRamone
    AprilRamone TPF Noob!
    Nov 3, 2005
    1,280
    Denver
    Lucky you! I wish I had someone to make me things like this. I am sadly lacking in those sort of skills....
  6. Hertz van Rental
    Hertz van Rental TPF Noob!
    Nov 8, 2004
    16,728
    45
    Where am I now?
    There are several drawbacks with diffusion panels when compared to using a softbox or brolly.
    1) A large percentage of the light is bounced back off the surface and so approximately twice as much power is needed to give the same level of illumination as a softbox/brolly. That is to say, you lose about a stop.
    2) The light bouncing back off the screen can cause spurious reflections or colour casts by interacting with walls and objects that are not intended to be illuminated.
    3) They take up a lot of room in use.
    You also have to be careful what material you use as a diffuser - the wrong stuff can give colour casts and/or patterns.
    The position of the light is also critical. Too close to the screen and you do not get enough diffusion (and the light becomes more of a point source). To far back from the screen and even less light is transmitted by the screen.
    Having said all that, they can work reasonably well if you bear those points in mind and you have nothing better to hand. They actually work better for modifying sunlight.
    A better (and easier) light modifier is to just use two white boards.
    The boards can be any convenient size (6' to 8' for full length portraits), and made of a variety of materials.
    Large sheets of expanded polystyrene work well, or flat boards covered with white paper - even just painted white with a suitable paint.
    Fix the two panels together in a 'V' (like the diffuser panel set up).
    Place the panels in the position you want light to come from, with the bottom of the 'V' furthest from the subject.
    <o like that.
    Place your light (two lights better) pointing in to the 'V' (with two lights have one at the top, one at the bottom).
    You will get an effect like diffuse daylight.
    The V shape stops light spill, makes the 'diffuser' directional and ensures that nearly all the light goes on the subject.
    Any lights will work - strobe, tungsten, quartz...
    Cheap and easy. I (and a lot of other photographers of my acquaintance) used the set-up successfully for years.
  7. Mike_E
    Jan 26, 2007
    5,327
    266
  8. Rhys
    Rhys TPF Noob!
    Jan 26, 2008
    975
    Columbia, SC
    Hmm... My experience of building PVC tubes up as a background stand is that while lightweight and portable, they were not very robust. My main problem was that the 90 degree angles were not robust and the pipes were too flexible. The whole thing wobbled badly no matter how much I tried to brace it and in the end I concluded it was not safe enough to use around clients.
72inch incm
diffusion panel photography
diffusion panels photography
how do i use diffusion panels in my photography
how to use a diffusion panel
how to use diffusion panel
how to usea diffusion panel in portrait photography
kandheld diffusion panel on location
photography cheap diffusion panels
using diffusion panels
