Digital Camera Lens question.
Discussion in 'Digital Discussion & Q&A' started by fotoadam, Oct 28, 2004.
  1. fotoadam
    fotoadam TPF Noob!
    Aug 12, 2003
    80
    houston and huntsville texas
    Im curious, Are there lenses that are specifically designed for digital camera use..? Lets say I have a 300D and wanted a 15-80mm lens for it. Could I use anyone I can find in a magazine or does it have to say for digital use only or what not..? Thanks
    ADam
  2. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
    I know very very little bout this, so take it all for what it's worth. There are lenses just for digitals. Or rather, they're designed for digital cameras. Nikon and Canon sell them with an anti-shock feature. Then you also have the multiplying factor. Because the size of the sensor in a digital camera is different to a film negative, when you use a non-digital lens the focal length of the lens becomes longer.
    That is about all I know. I'm sorry I can't give you any conrete information. I'll be watching this thread though. Even though it relate to me in no way, I'm interested in the answers.
  3. j_mcquillen
    j_mcquillen TPF Noob!
    Oct 3, 2004
    290
    Northumberland, UK
    If you have a Canon 300D, then any lens from the Canon range should work with it - assuming they're not older lenses with a different fitting.
    You can get lenses that are specifically designed for digital camera - some of the independant manufacturers like Sigma make these, but in general, any lens designed to fit a Canon Auto Focus camera should work with the 300D
  4. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
  5. Artemis
    Artemis Just Punked Himself
    May 16, 2004
    5,313
    43
    England! w000t!
    I have an Olympus C-4000 that is virtually a compact camera...but you can attach new lenses onto the end of its old ones...so they are just for digitals!
  6. Artemis
    May 16, 2004
    5,313
    43
    England! w000t!
    Just found this for yah!
  7. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
    Yeah, it was in the link I posted. ;)
  8. Artemis
    May 16, 2004
    5,313
    43
    England! w000t!
    yeh sorry..thats what I meant, just thought i ould quote it to make it easier! :) sorry didnt mean It was my find as such....
  9. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Digital SLR cameras (Canon, Nikon, Pentax etc.) have the same mount as their film counterparts. Therefore you can use the same lenses for your Canon EOS (auto focus) film camera as you can for your Canon digital EOS cameras.
    Now, the most common DSLR cameras do not use a sensor that is the same size as 35mm film, which the lenses were designed for. So the sensor only sees part of what the lens sees...thats why we have the crop factor. For the 300D it's 1.6.
    It's often said that this makes your lenses longer on the digital camera...that's not true. The magnification is exactly the same as when using film...but the view that reaches the sensor is smaller. So the field of view that you get will be different on a film camera vs. a digital without a full frame sensor.
    Canon has made a few lenses that are ultra wide and specifically designed for their DSLR cameras. The EF-S series lenses. The reason they are only for the digital cameras is that the rear element of the lens sticks back into the camera farther than a normal lens...which would interfere with the mirror on their film EOS cameras.
    There is another subtle difference in some of the new "digital" lenses. They put an anti reflective coating on the rear element of the lens so that any light that reflects off of the sensor, is not reflected off the lens and back onto the sensor. For this reason, some older lenses may produce some funny things on your digital images...but from most accounts...this is a very minor problem.
  10. green
    green TPF Noob!
    Jul 16, 2004
    135
    I'm a big fan of buying standard lenses that can be used for both film and digital. then, all I need is a film body and I can rotate between the two based on my need and mood. if you want to stick with only digital, I'd get whichever fits your budget and fits with the quality you'd like to see.
  11. jadin
    jadin The Mad Hatter
    Feb 18, 2004
    1,740
    9
    Down the Rabbit Hole.
    For Nikon any lens marked DX is digital only. You might be able to use them for other cameras but most if not all features will be disabled.
  12. Scurra
    Scurra TPF Noob!
    Aug 19, 2004
    1,159
    7
    Kent UK
    If you have a Canon and want a digital specific lens they have started to create the EFS range which only fit the digitals and I believe attempt to rectify the multiplier problems you get with standard lenses... I have an EFS that came with my 20D.
