Digital Camera
Discussion in 'Photography Equipment & Products' started by rodeofoto, Dec 14, 2005.
  1. rodeofoto
    rodeofoto TPF Noob!
    Sep 28, 2005
    38
    Hello,
    I am finally going to take the plunge.
    What Digital camera would you suggest for me?
    Right now I have a Minolta 7000 and use my 300 lens the most. I take alot of high action, long distance photos (Rodeo).
    Any suggestions are most welcome.
    Thanks!
    Weezy
  2. Cipriano
    Cipriano TPF Noob!
    Dec 13, 2005
    85
    Portugal
    IT depends. Do you have money to spend?? For what use you want the camera....
  3. rodeofoto
    rodeofoto TPF Noob!
    Sep 28, 2005
    38
    I am thinking I will need to spend between 2500- 5000? Do I need to spend more?
    Here are the type of photos I take www.rodeofoto.com/gallery
    Weezy
  4. Mack
    Mack TPF Noob!
    Dec 11, 2005
    150
    what currency? I'd look at at the 20D or 10D:)
  5. Cipriano
    Cipriano TPF Noob!
    Dec 13, 2005
    85
    Portugal
    Is that € or USD or dollars?
  6. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
  7. maxxum
    maxxum TPF Noob!
    Feb 25, 2005
    23
    Maxxum 7D are nice. But I think the 9D is rumored to be out this spring. If you have alot of good lenses you might want to stay with Minolta.
  8. kelox
    kelox TPF Noob!
    Mar 22, 2005
    1,434
    24
    Coming to you live from Planet MAXXUM, home of the
    The 9D is just that, rumored to be in the works. That is going to cost big bucks. The 7D can be had for $800-$1000, depending on where you buy it and whether or not you get a lens with it. The 5D looks like a nice deal, but if you want more manual control, the 7D would be better.
  9. rodeofoto
    rodeofoto TPF Noob!
    Sep 28, 2005
    38
    Thanks for your help!
    Do 35mm lenses work on digital cameras?
    Weezy
  10. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    If the mount is the same, it should work. Canon digital EOS cameras work with all the same lenses as EOS film cameras. Same thing with Nikon...I'm think Minolta should be the same.
    One thing you have to be aware of is that most digital SLR cameras have a sensor that is smaller than a 35mm negative...so therefore only the centre part of the image is recorded...effectively giving your lenses a "crop factor".
    On my Canon, the crop factor is 1.6 so a 50mm lens feels more like an 85mm lens.
    This is great on the telephoto end but bad when you want to go wide. That's why they have been making digital-only lenses that have a smaller image circle. I don't know if Minolta has any lenses like that or not.
  11. rodeofoto
    rodeofoto TPF Noob!
    Sep 28, 2005
    38
    Thanks for the info Chuck!
    Weezy
