digital lens on film body, canon
Discussion in 'Photography Equipment & Products' started by den9, Oct 6, 2009.
  1. den9
    den9 TPF Noob!
    Dec 8, 2007
    572
    Doylestown, PA
    i put a nikon dx lens on a d700 and it mounted fine.
    i just tried putting a digital lens on my canon 1N film body and it doesnt fit, im assuming they are different mounts? i know the 1N is a EF mount so i cant figure out the problem.
  2. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Since your Nikon lens is not EF mount lens, so it should not be mountable on the EF mount body. (It has nothing to do with digital lens on film body)
  3. den9
    den9 TPF Noob!
    Dec 8, 2007
    572
    Doylestown, PA
    your confused.
    im talking about a canon digital lens, trying to put it on a canon film body. i dont care if it vignets, im just trying to see if it will mount. but it wont, the canon isnt a fd mount.
  4. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
    EF-S lens cannot be mount on a FF Canon EOS body nor 35mm Canon EOS Film body.
    EF lens can be mount on a APS-C Canon EOS body, FF Canon body or 35mm Canon EOS body
    In other words, Canon APS-C EOS camera can mount EF or EF-S mount lenses. Other Canon EOS camera can only mount EF mount lenses.
  5. Big Mike
    Dec 16, 2003
    33,854
    1,818
    Edmonton
    Firstly, lenses aren't digital. ;)
    If by digital lens, you mean a Canon EF-S lens....then yes, it's a slightly different mount than the standard Canon EF mount.
    This is partially because the image circle of an EF-S lens is not big enough to cover a full frame sensor (or 35mm film). Also, some EF-S lenses extend back into the body farther than EF lenses, which may interfere with the mirror swing of a full frame or 35mm body.
    A friend of mine did 'hack' his EF-S 10-22mm lens so that it does fit on his 1 series digital bodies, so it can be done.
  6. den9
    den9 TPF Noob!
    Dec 8, 2007
    572
    Doylestown, PA
    interesting, kinda sucks. i had a 12-24mm dx lens on a D700 once, worked at 18mm.
canon digital lens on film body
canon new lens on film body
ef lenses on film body
ef-s lens on 35mm film body?
ef-s lens on film body
efs lens on film body
film body digital lens
fit new canon lens on film body
rent nikon lens doylestown pa
will a ef film lens fit a ef digital
