DIGITAL STUDIO LIGHTING
Discussion in 'Beyond the Basics' started by PMPHOTO, Nov 21, 2008.
  1. PMPHOTO
    PMPHOTO TPF Noob!
    Nov 21, 2008
    12
    I have 3 JTL Versalight 300 strobes that I have been using for portrait work with my 35mm Nikon. Can these lights be used if I get a Digital Camers??? Or do Digital cameras require special studio lights ??? I have been shooting weddings and portraits for years with 35mm. The times have now cought up. :(
    Thanks for your help.
    Fred
    [​IMG] [​IMG] [​IMG]
  2. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    they should work just fine
  3. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Chris has what I believe to be the right answer, they should work just fine.
  4. Mike_E
    Jan 26, 2007
    5,327
    266
    If you stick with Nikon then yes they should. If you go with another company then you should check the trigger voltage because if it's too high then it might fry your new DSLR.
  5. Alleh Lindquist
    Alleh Lindquist TPF Noob!
    Oct 2, 2008
    244
    Portland OR
    Lights are lights! Don't matter what camera you have.
  6. JerryPH
    Oct 14, 2007
    6,111
    15
    Matters if they are battery powered flashes... and are the older ones and have a higher internal voltage... they could fry a camera. However, since in a studio, *NO* flash is placed on a camera, he's fine. :)
    So... you BOTH were right, ok? :lol:
  7. SpeedTrap
    SpeedTrap TPF Noob!
    Oct 2, 2006
    1,392
    26
    Edmonton
    JTL strobe are Monolights, they will work fine with any new DSLR.
  8. Mike_E
    Jan 26, 2007
    5,327
    266
    LOLOLOL Some people still use PC cables. They might not want 200V going through a 50D.
    I'm not saying that's what would happen but I am trying to pass along a very useful bit of information about trigger voltages and digital cameras to someone who is new to them.
    Like your needing to be careful what you hook up to a DSLR. ;)
  9. Village Idiot
    Mar 20, 2008
    7,274
    406
    Most all new DSLR's handle trigger voltages up to 250v.
  10. andrew99
    andrew99 TPF Noob!
    Jan 23, 2008
    672
    Toronto, Canada
    Nikon is very good with backwards compatibility. You'll be able to use your old lenses as well as flashes. Which camera bodies are you looking at?
  11. monkeykoder
    monkeykoder TPF Noob!
    Nov 19, 2007
    4,143
    Sacramento CA
    Some will only handle trigger voltages of up to 5v (Canon seems to be the worst at this according to my research). Supposedly some of the Nikon models can handle up to 250v but I wouldn't trust my camera to it without direct confirmation from Nikon.
  12. Village Idiot
    Mar 20, 2008
    7,274
    406
    It actually says in the Nikon manuals that they can handle up to 250v at the sync port. Just look up any PDF and go to the flash section.
    There was a blog some where with a response from Canon customer service that stated the same thing.
%22digital+studio lighting%22
popphoto.com, mark lent, studio light
using versalight 300 with canon dslr
