Digitizing slides with a camera
Orrin
Sparks, Nevada
Website
www.orrin.org
I needed some digital images of some of my color slides. Using the scanner on my Canon MP990 takes a long time and, in my case, requires firing up an old Windows computer.
(The MP990 does not talk to my Linux system in the scan mode!)
Since my Canon SX130 will focus down to 1 cm in macro mode, I decided to try taking a photo of a slide. Since I have a tabletop device to hold the camera and a Logan 4x5 light panel, it was only necessary to cut a mask out of cardboard.
The raw image from the camera...
After a little work in the Gimp...
Monochrome negatives can also be scanned as long as your image editor can change it to a positive. Color negative will require a lot of editing due to the orange mask.
What Linux are you using ?
It's not the correct forum to discuss computers, but I am using hardware from 2006. The base system is OpenSuse 11.3 which will not support modern browsers and was developed long before the MP990 (thus no drivers).
For online I use a version of Puppy Linux that loads into memory and leaves the base system alone. It supports the MP990 for printing & document scans but not film scans!
:1247: Did you try something Debian based ? Like Mint ? Canon made debian and rpm packages for MP990. Here:
Canon PIXMA MP990 Driver Download - Canon Europe
The hardware is too old to support any of those...I've tried!
Since I am in my mid 80's, what I have will probably last!
Quite a credible digitizing result, I think! Sure beats holding the 'chrome up to the light and squinting through a loupe, right?
OK. :icon_thumbsup:
