C. Brian Kerr
- Joined
- Mar 25, 2015
- Messages
- 351
- Reaction score
- 144
- Location
- Salisbury, Md
- Can others edit my Photos
- Photos NOT OK to edit
This is a nice sequence. My concern is that the first one does not seem to be totally in focus - its head is a bit fuzzy. The third one also seems a bit fuzzy around the edges. The bird is not in as sharp a focus as I would like to see it, when I compare it with other osprey shots that are posted in this forum.
WesternGuy
Have you looked at the new 150-600mm lenses from Tamron and Sigma. From what I have seen, both are quite good. The Sigma is a bit heavy for continuous hand-holding though. Neither will set you back an arm and a leg, or more, like a full blown 600mm long lens will.This is a nice sequence. My concern is that the first one does not seem to be totally in focus - its head is a bit fuzzy. The third one also seems a bit fuzzy around the edges. The bird is not in as sharp a focus as I would like to see it, when I compare it with other osprey shots that are posted in this forum.
WesternGuy
This is a super tight crop. Still saving for my long glass but need to keep practicing in the here and now. Thanks
Personally, I went with the Sigma, although it is a little heavy, but then how many images are you going to shoot with a handheld 600mm lens - for me not too many. I have seen images from both lenses and to me, at least, the Sigma is the sharper lens (now don't all the Tammy folks jump all over me - its just my personal opinion based on what I have seen on a number of different forums). It is a bit more $$ than the Tammy and you probably have to get the "dock" to keep its firmware up to date, but that's just the way it is. I haven't had too much opportunity to use mine yet as things are just starting to thaw out here, but I am hoping to get out tomorrow and try it out (assuming it doesn't snow as they are threatening).I'm still deciding on which to go with. These where taken with my sig 70-200. I have awesome opportunities and am currently saving to get the longer glass. Both the lenses I have now are sigma
