dirt IN the lens
Discussion in 'Beyond the Basics' started by spiralout, Jan 2, 2005.
  1. spiralout
    spiralout TPF Noob!
    Nov 11, 2004
    679
    4
    University of Houston
    I have a D70, and I've noticed that there are quite a few small black spots scattered throughout any shot I take. I looked at my lens the other day and noticed a tiny bit of dirt UNDER the first lens element. I clean my lens after every use (dust the glass off and wipe the body down). The only reason I could think of is the day that I spent at a rock crushing plant. I have a zoom lens so perhaps some of the dirt could've found it's way into the lens. But I still have NO idea how it couldn't gotten up to the second element. Is this an expensive thing to get taken care of?
  2. AIRIC
    AIRIC TPF Noob!
    Jul 27, 2004
    4,801
    83
    Brooklin, Ontario, Canuckia
    Sounds more like you have lots of dust on the CCD from changing lenses. The D-70 has a mirror lock up feature that will allow you to clean the CCD. Its in the manual but be careful.
    Eric
  3. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,762
    46
    Ahwatukee, AZ
    Dust is a camera's worst enemy. I try to keep the camera shielded from dust as much as I can in any dusty environment. I have a few plastic shower caps from various hotels and motels and I fit the camera inside with the lens going through the opening. A small hole where the viewfinder is and I'm in business.
    If you want to clean your camera/lens though, is best to take it to a camera shop.
    Good luck.
  4. doxx
    doxx TPF Noob!
    Aug 4, 2003
    499
    behind the viewfinder
    like Airic said - it's mostlikely some dust on the sensor,
    dust in/on the lens doesn't show as much...
  5. C_lawgik
    C_lawgik TPF Noob!
    Jun 10, 2004
    121
    Moapa Valley NV by Vegas
    try taking pics of paintball. you deal with the dusta dn slow ith paint, sweat and grime.
  6. will965
    will965 TPF Noob!
    Nov 27, 2004
    214
    England
  7. spiralout
    spiralout TPF Noob!
    Nov 11, 2004
    679
    4
    No, it certainly isn't from changing lenses as I only have one. I just checked the ccd and it's spotless. I even blew it a few times for good measure. I noticed that there are a few visible spots when I look through the viewfinder, so I cleaned the mirror and ground glass. The spots are still there.
