Disadvanteges of frequent cleaning?
Discussion in 'Photography Equipment & Products' started by Val, Jan 30, 2008.
  1. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    If i set my camera to clean sensor on every on/off operation, are there any reasons not to do it? Camera is D300.
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I think it uses vibration to 'shake' the dust off...so I guess you could save some wear and tear on the moving parts, if you turned it off....but that technology is probably a bit too new, to know if that will actually make a difference.
    It might also save you some battery power.
  3. Trenton Romulox
    Trenton Romulox TPF Noob!
    Mar 10, 2007
    2,392
    Maine
    I've shot 5,000 clicks with my D300, and changed lenses at least twenty times, but have not yet cleaned the sensor. Should I? I'm kind of scared to HAHA.
  4. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    20 times? I have 3500 clicks and about 350 changes :) and im 18-200 kind of guy!! :D
  5. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    Like Mike said its yet to be determined if that will damage your camera but I would imagine the more something is used the moe likely it is to break. Only clean your sensor when you notice dust specs in your photos, no reason to clean a clean sensor.
  6. Trenton Romulox
    Mar 10, 2007
    2,392
    Maine
    Why do you change so much? HAHA.
  7. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    Apparently when there is noticable dust its already too late. Youll have to clean it the hard way.
    Well... I do some normal shots, then i do some macro shots, then i do wide shots then i get a prime for fun then i get bored and do normal shots again etc etc etc :)
  8. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    Changing lenses is a must. Shooting in the same focal range all the time really limits you. I guess Romulux must not any primes or aybe he has a real solid 10 to 300mm lens sharp throughout.
    If the built in sensor cleaner will not clean noticable dust off a sensor what is it good for?
  9. RKW3
    RKW3 TPF Noob!
    Apr 30, 2007
    1,716
    So Cal
    Only 20 swaps? Yeah that's a very small amount, I only have 2 lenses to choose from, but I still find myself making a ton of changes.
  10. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Makes no sense what so ever. If there's no visible dust there's no dust to shake off. This isn't a startrek force field, it's a ultrasonic vibrator. The dust particles will be sitting staring thinking wtf is that sensor doing.
  11. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    The theory behind it is that visible dust is mostly clustered small pieces, not big ones. So its easy to shake of small seeds rather then formed clusters.
    Again, this is just what i was told :)
  12. gendarmee
    gendarmee TPF Noob!
    Dec 30, 2006
    123
    One theory says that the moving parts of the camera inside also add to the dust due to wear and tear..like the shutter ect.
    Going by that theory, Would the vibration mechanism also produce particles over time?
