Distorted people - need help
Discussion in 'People Photography' started by mamadada, Aug 10, 2010.
  1. mamadada
    mamadada TPF Noob!
    Dec 9, 2008
    8
    I am fairly new to the photography things, so pleeze bare with me. I am sure this has been posted 1K times. However, I must not be using the correct words in searching. What kind of lense should I use to photograph people in full standing positions fairly close up? Everyone comes out distorted or convex looking. Larger at the top and feet look smaller. Help???!!!:(
  2. Petraio Prime
    Petraio Prime TPF Noob!
    May 28, 2010
    1,217
    Ohio
    The problem isn't the lens, it's the fact that you are close to them.
  3. mamadada
    mamadada TPF Noob!
    Dec 9, 2008
    8
    Am I using the wrong terminology and is there any other solution? I tried a 55-200 mm lens and I have to get too far and then have flash issues and also if I am trying to shoot in a crowd well that's impossible isn't it?
  4. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Different lenses will give you differing amounts of distortion...but for the most part, the wider the lens and the closer you are, the more of this type of distortion you will get.
    So yes, the solution is to back and and/or use a longer lens. If that gives you flash issues, then get a more powerful flash and/or move the flash off-camera. If crowds are an issue, then figure out a way to avoid them.
  5. mamadada
    mamadada TPF Noob!
    Dec 9, 2008
    8
    Can you give me an example of a better flash? I only bought the sb400. I though for sure there was a lens solution.
