Disturbance on developed film
Discussion in 'The Darkroom' started by Dagfinn, Mar 10, 2009.
  1. Dagfinn
    Dagfinn TPF Noob!
    Aug 20, 2008
    7
    Hello,
    Having tested an old Minolta SRT-101 for the first time, I have just developed a film of Ilford HP5 plus 400, and find to my surprise that all the negatives have these equally spaced dark fields which start at the wide end and fade into the image.
    http://img12.imageshack.us/img12/324/testisk.jpg
    What on earth has happened here?
    Thanks for any feedback.
  2. Dagfinn
    Dagfinn TPF Noob!
    Aug 20, 2008
    7
  3. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    Hair, I get it all the time.
    Wipe off the negitive before scanning/enlarging. Any that remain can be cloned out if absolutely necessary.
  4. JC1220
    JC1220 TPF Noob!
    Sep 13, 2005
    439
    Maine
    You will find that these correspond with the sprocket holes, if they are dark on the negative, they are a sign of light leaks. Search the forum for related words, I am sure there are a few threads showing the same thing.
  5. compur
    compur Been spending a lot of time on here!
    Mar 6, 2008
    3,036
    508
    L.A.
    Looks like you need to replace the light seals -- the foam strips that fit
    around the edges of the film chamber area. A common situation on Japanese
    cameras from the 60s-80s.
  6. Battou
    May 10, 2007
    7,997
    26
    ...I missed that, holy crap.
  7. Dagfinn
    Dagfinn TPF Noob!
    Aug 20, 2008
    7
    Light leaks! As I somehow suspected. Will some thick black tape along the chamber edges do the trick?
  8. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    6,182
    940
    Woodbridge, Ontario, Canada
    You posted a postive image.
    As JC mentioned ... these streaks will appear dark on the negative ... and light on the print.
    Your positive image shows them as dark ... so I expect it to be light on the negative. If this is correct ... then this is not a light leak.
  9. compur
    Mar 6, 2008
    3,036
    508
    L.A.
    ^ Good point. It could be a developing issue. Perhaps over-agitation.
  10. randerson07
    randerson07 TPF Noob!
    Apr 4, 2008
    279
    Pingree Grove, Illinois
  11. dxqcanada
    Dec 4, 2008
    6,182
    940
    I would say that the developing tank was not agitated properly.
    I would guess that the dark areas are right under a sprocket hole.
    Developer has not washed down under the holes, thus causing underdevelopment.
  12. Actor
    Actor TPF Noob!
    Mar 4, 2007
    421
    Ohio
    These are called "surge lines."
    From Mastering Black-and-white Photography by Bernhard J. Suess, Allworth Press, New York, 1995, pp 52-3.
