DIY Custom Camera Bag (on a budget!)
Discussion in 'Photography Equipment & Products' started by mimstrel, Sep 14, 2008.
  1. mimstrel
    mimstrel TPF Noob!
    Jun 27, 2008
    115
    A few months ago I mentioned that I was planning to make a camera bag for all of my camera gear, so it isn't so much all over the place. Someone requested that I do a tutorial to demonstrate how I go about this.
    I'm just starting now but thought I may as well begin posting the how-to in case anyone is interested. Please try to ignore the complete lack of composition and occasional blurriness of the photos - I'm working on this all in my dorm room and space and lighting is at a premium!
    As a short disclaimer: This is not a good project for a beginner. It's not that I want to discourage people from trying new things, but do yourself a favor and practice on something simpler first. If you are trying this or trying to design your own bag not based on mine, feel free to pm me if you get stuck.
    OK, now to start:
    I do want all of my current camera stuff to fit into this backpack, with room to add maybe a dSLR and a couple more lenses, BUT I want it to be modular. Oh, and I want it to be inexpensive. So here's most of what I want to put in at the moment:
    [​IMG]
    That is: my three digital point and shoots and their various accessories, and my grandpa's Nikkormat FTn 35mm SLR plus its flash and lens... plus whatever else I might obtain in the near future.
    Now, if you are interested in making your own camera bag, you may be thinking, "But I have different stuff," but I assure you that my directions are generic enough that you should be able to easily adjust to your own situation.
    My plan is to create a backpack with a main compartment which is split in half for the larger camera bodies and the SLR lenses, a smaller but still large compartment for batteries, memory cards, cords, and other accessories, and three small pockets for the 2 smaller point and shoots and the waterproof case. As I progress I will mention how you can customize this plan so that you may follow this tutorial and come up with something that looks nothing like mine!
    Because I don't have a sewing machine in my dorm right now, I am beginning with the removable pockets. There will be many, and I am attatching them via snaps. Velcro, ties, buttons, and keyrings can all be used. Most people would use velcro, but I don't like that the rough side of velcro snags things.
    I am creating two basic styles of pocket: flat and box. Flat works well for batteries, memory cards... things that are flat. Boxes work well for battery chargers and other things that are not flat.
    Here is the basic directions for a flat pocket: (Keep in mind that you can do this MUCH faster by machine sewing!)
    [​IMG]
    Taking into consideration the size of your object and how many you want to fit in your pocket, cut out a piece of fabric big enough to fold in half and fit the item(s) inside. I am using flannel for the lining of this pocket and denim from old jeans as the exterior. You don't have to do a lining if you don't want to. Fold the fabric in half, right sides together, and sew around so that one side stays open. I usually stitch it twice when handsewing to be sure the seam is sturdy. Do the same for both the lining and exterior fabric if you are lining your pockets. Turn the exterior right-side-out and place the interior into it.
    [​IMG]
    [​IMG]
    In this case I added a zipper as I was sewing the interior and exterior together. DO NOT USE A ZIPPER ON A POCKET THIS SMALL. It was ridiculously hard to wrestle into position with so little space to maneuvre. To close a pocket of this size, add a flap by sewing a piece of interior to a piece of exterior and seaming it into one side of the pocket. Then you can close it with whatever type of fastener you want!
    Here's how to do a box:
    [​IMG]
    Again, take into consideration the size and number of items to go into the pocket (In this case I am making a box for my current and future filters). Cut out a cross shape. I made this one with all 4 arms the same length - I recommend creating a "lid" by making one arm twice as long. The length of the arms is how deep the box will be. Again, I am lining all my pockets. You can just as easily skip the liner.
    [​IMG]
    Fold the arms of the cross up to make a box. Then, right sides together, seam each of the corners.
    [​IMG]
  2. mimstrel
    mimstrel TPF Noob!
    Jun 27, 2008
    115
    [​IMG]
    Now do the same with the exterior. Note that if you are making a built in lid, it will just be flapping here.
    [​IMG]
    Once your lining and exterior are both sewn up, turn the exterior right sides out and place the lining inside (I just put the filter in to keep everthing steady).
    [​IMG]
    Since I didn't put a built-in lid on this one - originally I was going to leave it without - I had to make a flap as described above. Its just a piece of lining and a piece of exterior cut to fit on top and hang over the other side a bit. If you need to do this, sew it onto the exterior as shown and then sew it into the interior.
    [​IMG]
    Remember to fold the raw edges (the part that frays) inside!
    [​IMG]
    I'm doing an invisible stitch around the outside with the raw edges turned in so that the finished product has no visible raw edges. This is only possible with a lining. And, in this case I wish I had added a zipper. Oh well, live and learn!
    [​IMG]
    I'll probably close this with a button - a snap or velcro would work too - but you can see why a box this size and shape should probably have a zipper to keep the sides closed.
    [​IMG]
    [​IMG]
    Here you can see the back after I added snaps - snaps will go on all of the removable pockets, and the other side of the snaps will go inside my bag once it is finished.
  3. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    Nice work!!!
    I'm more inclined not to use metal snaps and zippers in my back. I rather use velcro and pull/ties. For example, I throw my lenses into a bag (their own compartment) without caps... I would not want to risk scratching elements.
  4. mimstrel
    mimstrel TPF Noob!
    Jun 27, 2008
    115
    All of the snaps will be in a seperate compartment from where the lenses go. Nothing scratchy will be in the compartments with the camera bodies or the lenses.
    Thanks!
diy camera backpack
diy dlsr backpack
diy dslr backpack
diy dslr camera backpack
