do memory cards wear out?
Discussion in 'Photography Equipment & Products' started by emogirl, Jan 9, 2007.
  1. emogirl
    emogirl TPF Noob!
    Nov 22, 2006
    622
    Lindsay, Ontario
    I was told once that memory cards do wear out....kind of like a video tape being tape over so many times, eventually the quality goes kaput. Is this true? The reason I ask, a friend sent me pics from her camera and she is haivng problems....mostly streaks thru all her pics, i have never seen anything like it before in 15 years of photography....having gone over her camera and pics thoroughly, that is all that i could come up with. Since I am quite new to digital, I need your folks help!!! Sorry, i dont have the pics anymore to show you.
    thanks, Kim
    Please feel free to move this thread to the correct forum if i'm not there.
  2. emogirl
    emogirl TPF Noob!
    Nov 22, 2006
    622
    Lindsay, Ontario
    im bumping this in hopes of getting an answer...thanks'
  3. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    I don't know but you looked lonely... My guess is that it would take a long time and more likely have an accident first but i guess everything wears out eventually.
  4. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    I would guess that the camera would have problems before the card...there are just so many more things that could go wrong with a camera. The test is simple...just try the card in a different camera. If the problem persists with both cameras...then it's the card...If not, then it's the camera :(
  5. emogirl
    emogirl TPF Noob!
    Nov 22, 2006
    622
    Lindsay, Ontario
    yes....that was our solution, she was trying the little card that came with her camera and see what happens....in the meantime, while i'm waiting to hear back from her, i was trying to find out about the memory card wear....so i'm guessing you have never heard of that??
  6. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    I've heard of them 'going bad' or just being bad from the start...but either people don't say what the actual problem is...or the files are corrupt. I've never specifically heard of a card causing streaks.
  7. mysteryscribe
    Feb 1, 2006
    6,071
    As an after thought I have a digital camera I shoot things for ebay with. It ruins memory cards for some reason. Once they have been formatted in the camera they can not be read by anything else. I had to hook the camera to the computer to read the cards. I don't use that type for anything else so it's okay with me. I also will never in my whole life fill that little card up.
  8. tasman
    tasman TPF Noob!
    May 7, 2006
    468
    Edmonton, Alberta, Canada
    Memory cards can become unusable, or corrupted in some way. It is probably from a static shock of some sort. Either from the camera or when it was removed and put into a reader. Either way it is probably better to get a new card and not use a corruted card and risk loosing your photos.
  9. Player_1
    Player_1 TPF Noob!
    Jan 13, 2007
    27
    I have a card that I've taken over 9000 pictures with. It never burned out, so I figure it's ok.
  10. Anubis
    Anubis TPF Noob!
    Nov 12, 2004
    285
    Sunny Scotland
    My CF card says "good for 10,000 insert/ejects". So it should be good for about 46000000 photos. (Plus, I never eject it, I always hook my camera to the PC and don;t use a card reader. So hopefully I'll get more :p)
  11. boclcown
    boclcown TPF Noob!
    Aug 16, 2006
    74
    technically, all digital media has some sort of life-span. DVD's are supposed to last between 75 and 100 years, I think, and I'm sure CF cards have a life span as well. Thing is, it will be extreemly long, and there is a much greater chance of something going wrong with th card (static shock, being dropper, corrupted, etc.) than the card just dying out.
    In most cases, I would think that by the time the CF card actually dies, CF will have long been replaced by SD or something along that line.
  12. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    i have heard somewhere that the lifespan of CF cards is limited by the number of writes/erases on it
    but this is purely based on something i think i remember, it might be totally wrong.
