do polarizers do anything for sunsets?
Discussion in 'Photography Beginners' Forum' started by rasheemo, Aug 4, 2008.
  1. rasheemo
    rasheemo TPF Noob!
    Jun 30, 2008
    162
    Wayne, NJ
    and should i deliberately underexpose for a sunset?
    thanks in advance guys!
  2. KhronoS
    KhronoS TPF Noob!
    Oct 8, 2007
    345
    Romania, Galati
    Not really, polarizes are for landscape photos to block reflections from leafs, water, wet rocks, etc.
    I might be wrong though.
  3. tirediron
    Jul 8, 2005
    40,906
    12,421
    Victoria, BC
    Polarizers will do nothing for sunset images, except act as a sort of faux neutral-density filter if you want. To get the optimum results from a CPOL, you need to have your lens at 90 degrees to the sun, with the sun low in the sky. The closer you shoot toward the sun, and the higher in the sky it is, the less effect you will see.
  4. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    And for clouds/sky enhancement.
    With a sunset it will be quite useless in most cases, since you need a pronounced angle between your light source (the sun) and your optical axis to get any effect with the polariser. Since to shoot a sunset you look more or less right into the sun, that angle will be tiny, the optimum would be 90 degrees though.
    As for the exposure question, what doe underexpose mean here? you might have to deviate from your meter's readings, depending where you meter on. If you point the meter at the sun, you will have very different meter readings compared to metering on the surrounding sky or the foreground. hence if you blindly follow your meter reading, you might get very different exposures depending where exactly the camera is pointing.
  5. prodigy2k7
    prodigy2k7 No longer a newbie, moving up!
    Apr 22, 2008
    1,667
    22
    California, USA
    better colors
  6. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
  7. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    You're always one for clarity and detail in your posts.
    :roll:
  8. rasheemo
    rasheemo TPF Noob!
    Jun 30, 2008
    162
    Wayne, NJ
    well to capture a sunset as you see it, would you meter the sky away from the sun and then go back at pointing at the sun? i guess that's what i'm asking, because once i tried to photograph the moons reflection over the ocean and it was way too bright and i couldn't capture it as i saw it.
  9. TamiyaGuy
    TamiyaGuy No longer a newbie, moving up!
    Jun 25, 2007
    1,078
    Chelmsford, UK
    It's actually very difficult to capture a sunset "as you see it", as a camera has much less dynamic range than your eye. What this means is that those dark green trees you see in the background will be completely black when recorded on your camera's sensor (if you meter for the sun), and that beautiful red sunset will be almost completely white if you meter for the trees.
    Basically, you can't capture a sunset exactly as you see it, but I would switch to Center-Weighted metering, and meter for the sky. If you want to recompose, be sure to exposure-lock the sky first. Hopefully, it will come out OK. Best of luck!
