do you guys change the light settings?
Discussion in 'Photography Beginners' Forum' started by Wiggly, Oct 29, 2009.
  1. Wiggly
    Wiggly TPF Noob!
    Jul 17, 2006
    73
    in your camera? I mean like if you are inside and there is nothing but florescent lights and you have no flash... do you change your camera to florescent settings or fix it post processing? what if you DO have flash and are in a situation that calls for it combined with the florescents?
  2. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    I'm using auto white balance 99.99 percent of the time, in the rare instance I need to I can change it later in post (I shoot RAW).
  3. LarissaPhotography
    LarissaPhotography TPF Noob!
    Dec 27, 2008
    529
    Belleville, IL, USA
    I usually use the presets. In the past I've used the Kelvin setting.
  4. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    I use presets. It saves me time in post.
    Combining flash with fluorescent lights, or any light of a different temperature than the flash for that matter, requires the use of gels. And then life can become tricky with fluorescents, given that they shift colour throughout each cycle (60Hz here, 50Hz in Australia, Europe, or any other part of the world where AC power is output at 50Hz). And that means you're pretty limited, in having to use either 1/30, 1/60, or 1/125 to avoid shifts. Start going faster than that and WB between frames can get really funky (and no AWB won't save you in such an instance; not if you're using flash).
    I suggest you read-up on Strobist's Lighting 101.
  5. Village Idiot
    Mar 20, 2008
    7,274
    406
    To add on to this, unless using some sort of high speed sync feature, most modern DSLR cameras have an x sync (the fastest possible shutter speed to shoot out without banding from the flash vs. shutter timing) of about 1/250. There are some who have a slightly slower, slightly faster, or a "trick to obtain different x syncs, but 1/250 seems to be about average for most of them.
    AWB really isn't AWB, BTW. It shoots in a certain range, so if you're shooting inside with the AWB setting and still getting a very orange tine from the tungsten lighting, it's because the AWB setting shoots within a predefined Kelvin range and anything outside of that range will still have to be corrected.
    Generally speaking though, light sources don't change too much within a given area, so switching between custom, K settings, and the others isn't a big deal and will save you time doing manual color temp adjustments in post.
  6. musicaleCA
    May 23, 2009
    2,303
    Vancouver, BC
    Unless they're fluorescents. GRRRR!!!
  7. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    I usually set a white balance in ┬║Kelvin especially if I know the light source, then if I do tweak it in post its only a small change, and its easy enough to adjust a group of shots together since all of them are off by the same amount.
  8. SrBiscuit
    SrBiscuit TPF Noob!
    Apr 22, 2008
    2,721
    44
    NH
    always auto.
    it's horrible on the d1h, but i can alter in post thanks to raw.
  9. bigtwinky
    bigtwinky No longer a newbie, moving up!
    Oct 6, 2008
    4,820
    285
    Montreal
    Pretty much shoot on auto WB and in RAW ...and then adjust in post if needed
  10. ssnxp
    ssnxp TPF Noob!
    Oct 18, 2009
    104
    California
    I'm still a noob so I'm shooting in JPEG, therefore I'm learning to set the WB myself. I'm currently doing this with the white paper method.. don't have a gray card yet, but I might get an ExpoDisc later on.
  11. musicaleCA
    May 23, 2009
    2,303
    Vancouver, BC
    Grey cards are useful because they're easy to expose for. White cards are easier to blow-out, and then they're useless for WB (because all your values are 255).
    Are you using a white card, or a piece of white paper? Because paper that appears white to your eyes might not actually be white. Our eyes require a HUGE shift in colour from white to begin perceiving "off white"; the camera will pick-up smaller shifts.
  12. Buckster
    Buckster Been spending a lot of time on here!
    Sep 14, 2009
    6,399
    2,335
    Way up North in Michigan
    Used to shoot in auto and adjust it in post. I've recently begun to set a custom white balance in camera when I begin a shoot sequence. I've done that with 18% gray cards, white walls, white shirts, whatever's handy. I've just started using a Micro-Disc white balance tool (similar to an Expo-Disc) in the last couple weeks.
