Do you think this tripod would work wih my set up
Discussion in 'Digital Discussion & Q&A' started by notoriouslightning, Jun 18, 2008.
  1. notoriouslightning
    notoriouslightning TPF Noob!
    Jun 10, 2008
    69
    Austin TX
    I am very well aware that I should invest in a great high dollar tripod but for now I need something on the cheaper end. Under $100. That said does anyone think this tripod would work with my set up? I shoot with a 100mm macro, and xti body. This particular tripod is a Slik sprint mini.
    http://www.amazon.com/Slik-Sprint-T...UTF8&coliid=IA2MNZ7G50E7Y&colid=14HABMX6BSE69
    Any other particular recommendations? I would like to get it through amazon. Thanks a lot for any help.
  2. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    Two things that would concern me is:
    1) Maximum Height is only 43". (Just above my navel.)
    2) Maximum Weight Capacity is only 5.1 lbs. (Weigh your gear setup)
    Is $100 your max budget?
  3. John_Olexa
    John_Olexa No longer a newbie, moving up!
    Feb 3, 2008
    437
    49
    Maryland
    With your combo ( a macro lens) I don't see where it would be a problem.
    Check out B&H and Adorama also. I don't like amazon, but thats just personel.
  4. notoriouslightning
    Jun 10, 2008
    69
    Austin TX
    The tripod I am asking about is sold through amazon but the seller is Adorama. My xti with 100mm macro weight 2.27 lbs and the tripod say it will hold up to 3.5 the max height is a little short but I will mainly use it for macro. Thanks for the help
  5. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    [​IMG]
    Missed that part.
  6. reignmkr
    reignmkr TPF Noob!
    Jan 17, 2008
    53
    A good rule of thumb is a sturdy tripod should weigh the same or even more than your gear your going to mount on it.
  7. notoriouslightning
    Jun 10, 2008
    69
    Austin TX
    Well if thats the case my gear out weighs the tripod by 10 ounces. Any recommendations for other tripods close to or less than $100? Anyone have a used bogen manfrotto?
  8. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    Have you looked around at used gear? I know at home, between the local used store, and the second-hand websites, there are always a good selection. I can't see that one from work, however the description strikes me as one which won't satisfy your needs for long. Just my $00.02 worth - your milage may vary.
  9. PNA
    PNA TPF Noob!
    Mar 12, 2006
    2,771
    Wave when you see me go by.....
    Check the pawn shops.....
  10. notoriouslightning
    Jun 10, 2008
    69
    Austin TX
  11. PNA
    PNA TPF Noob!
    Mar 12, 2006
    2,771
    You can't go wrong with a Manfrotto......I personlly have model 3021PRO and am quite pleased. Don't know the going price, the wife bought for me it a few years back. It has the 3030 head.
  12. PNA
    PNA TPF Noob!
    Mar 12, 2006
    2,771
    They apparently discontinued the model.....
    The New SKU# is Manfrotto 055XPROB
    WOW ....pricey
