Does anyone here use a Nikon D40 for professional use?
Discussion in 'Photography Equipment & Products' started by Trish1977, Dec 6, 2007.
  1. Trish1977
    Trish1977 TPF Noob!
    Nov 26, 2007
    64
    Houston, TX
    Would I be able to do some portrait photography with a D40, or would I have to have a D80 or even D200/300 to get shots that "look professional"? I know that even with the best camera you can buy that some shots won't "look professional" because either the person using the camera doesn't know how to properly use it or they just don't have a "good eye", so let's assume that's not the case.
  2. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,700
    68
    Missouri
    I know a sports shooter who uses it outside for football with a flash because it has a 1/500th sync rate without having to use FP (not that you COULD use FP on a D40, not an option)
    Do yourself a favor and get a D80, D200 or D300 and skip the D40 for professional use...
    D80 is the MINIMUM I would consider.
  3. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    I agree, the D40 while capable of great images is too limited in features and build quality to use at the Pro level. It may work, but I doubt it would hold up for long.
  4. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    if you have it already...then I'm sure you could adapt it to some low level professional stuff. You could do indoor studio type work with it fine...
    But I certainly wouldn't count on it in a high stakes situation like a wedding or a one chance model shoot.
    I would say the D80 is a minimum if you're gonna buy a new camera.
    Just like I have a rebel XT, which I'm sure I could get away with in a studio...I would not want to get into any serious pro stuff, cause I know there's cameras that are more durable, more reliable, and with better picture quality...for Canon I would say a D30/D40 is a minimum...
    There are always those that will prove me wrong though...because I know lots of people use lesser cameras for much better results and higher pay.
  5. Trenton Romulox
    Trenton Romulox TPF Noob!
    Mar 10, 2007
    2,392
    Maine
    I have a D80, and I'd say the built quality is pretty decent. I'm not sure if it'd stand up to repeated professional-level use. Especially if you were a nature shooter, the body doesn't seem that well-sealed. I mean, I love my D80, don't get me wrong, but I'd be kidding myself if I said it strikes me as a 'professional' lens. And if the D80 isn't 'pro', the D40 sure isn't.
  6. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    I agree, and would recommend probably a D200 or 300 over it...but some people just can't afford it.
  7. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    You could easily produce professional results with a D40.
    Is it as fast, or durable as a more expensive body? no.
    But an 85mm f/1.4 looks exactly the same on a D40 as it does on a D2x.
    For professional operation, i'd be more concerned about the lenses than the body.
    The lighting, lenses, and how you take advantage of them are what's going to make professional looking images.
  8. Trenton Romulox
    Mar 10, 2007
    2,392
    Maine
    Actually, I'm gonna have to agree even though just above I said D40 for a 'pro' would be tough to do. A D40 with 'pro' lenses would produce 'pro' images.
  9. Trish1977
    Trish1977 TPF Noob!
    Nov 26, 2007
    64
    Houston, TX
    Thanks so much!!!!!! I'm finally getting really serious about learning more about photography so that I can start doing some "shoots" for friends and family (for experience, practice, and fun) and see if it's something I want to do for a living. Even if I never do it professionally I want to be able to take better photos than the average person who has just a p&s.
    Can I get good lenses that will work on the D40, D1X, and the D300? Is the lens that comes with the D40 a good enough lens to start with and does it also work with a D300 and D1X?
    I have a D1X that was just given to me. It was my father's back-up camera and he did professional children's photography. The problem is - it's very heavy, it's a bit overwhelming for someone just learning, it has no built-in flash (and I have no flash for it), and the battery is dead and I have no charger for it. I want to keep it and eventually learn how to use it, but I think for now instead of spending a lot of money on the things I would need to buy to get it "up and running" I'm thinking about getting a D40 for Christmas. Plus, I figure I can learn on the D40 and take some great photos right away and if I do decide to go professional in the future I can invest in a D300 or better. Plus, if I get a better camera in the future I can still use the D40 for some things and my husband can use it.
    I just hate sometimes that there are SO many choices and things to consider.
    THANK YOU, THANK YOU, THANK YOU for reading and offering advice!
  10. jstuedle
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    The D40 kit lens will work on the other cameras, but it's quality is really sub par. IMHO, you would be MUCH better off getting a battery charger, a couple batteries and the Thom Hogan e-book for the D1X. I have 3 D1X's and think they are still an outstanding camera. I think that even though I now own a D3. The D1X is not in the same league as the D3, but IMO it's a better camera than the D40 ever could be. A big advantage to the D1 series is you can use older manual focus lenses if you like and they will meter. Also, a used SB-80DX or new SB-800 flash will work much better than the built in flash on any DSLR. The D40 flash is really only good for about 10 feet. The cost of 2 new batteries, a used charger and a used flash should be cheaper than a D40. If you need a lens, pick up a 50mm f/1.8 for around $60-110 (used-new) and you are set. Believe me, you will have a much better camera that can do a lot more. As for the D1X's weight, my wife has small hands and does not mind the D1. Se does not like the "feel" of the all plastic D40, said it felt like a kids toy. (Before I tick off someone, her words, not mine. Even if I do agree with her. :) )
    P.S.
    To save money, you could get a SB-600, it will work on the D1X and D3/D300. It just is a lower powered flash than the SB-800.
    SB-800 new $320
    Battery new on ebay $30.00 X 2. (I have used these for a while and they work fine)
    Used battery charger on ebay $50.00
    Uesd 50mm f/1.8 on ebay $60.00
    total $490.00 or so.
  11. Snyder
    Snyder TPF Noob!
    Jul 21, 2007
    411
    9
    I travel all around the world
    When I shoot weddings and portraits in my free time I use a Nikon D200 and a D40 as my backup camera.
  12. Trish1977
    Trish1977 TPF Noob!
    Nov 26, 2007
    64
    Houston, TX
    Thanks jstuedle for giving me hope for the D1X and to Snyder for giving me hope for the D40.
    I think what I'll probably end up doing is getting the D40 mainly because it seems easier to use (for me=beginner) AND soon get all the stuff I need for the D1X. I'm going to try to get a second job at a portrait studio or camera store so I can have more money to do this stuff and learn at the same time. I think the Sears portrait studio is kinda lame, but they're hiring and I could get PAID (even though very little) to take pictures.
    Plus, all the serious photographers I know have SEVERAL cameras anyway, so it can't hurt to have both, right? AND, nothing I have or get is ever just mine anyway because my husband has at least a small interest in photography and it would be great if we BOTH had good cameras to use.
can d40 nikon take good potraits
how to take professional pictures with nikon d40
how to take professional pictures with nikond40
how to use nikond40 professionally
is nikon d40 good for professional photographers
make a portrait with nikon d40
nikon d40 for professional use
nikon d40 how to make good pictures
nikon d40 professional
nikon d40 professional use
