Does the 50D have a tendency to overexpose?
Discussion in 'Photography Beginners' Forum' started by JClishe, Aug 11, 2010.
  1. JClishe
    JClishe No longer a newbie, moving up!
    May 28, 2009
    826
    106
    Cincinnati, OH
    Whenever I'm shooting outside and in Av mode, I almost always have to dial down exposure comp to about -1/3 or even more otherwise I get blown out highlights. I actually leave it at -1/3 as the default and only dial it back up when needed. The other day I was shooting an old farmhouse during sunset and I still had to underexpose.
    Is this typical with the 50D?
  2. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,144
    2,945
    Chesterfield UK
    What metering were you using ?
  3. Robin Usagani
    Robin Usagani Been spending a lot of time on here!
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
  4. Overread
    May 1, 2008
    24,064
    4,171
    UK - England
    In stronger daylight I find I do the same with my 400D and its the same with many cameras. The meter is very accurate but it can be fooled, and in certain situations you have to learn (as you have done) to compensate for when the light will trick the meter.
  5. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Also, what are you using to judge that the images are overexposed? Don't rely on the image preview on the LCD...but rather use the histogram.
  6. Taylor510ce
    Taylor510ce TPF Noob!
    Jul 20, 2010
    702
    United States
    Turn on your histogram and look for "blinkies" I have had some situations where I needed to do the same thing. Thats why exposure comp is there, to be used.
  7. Ron Evers
    Ron Evers Been spending a lot of time on here!
    Jun 28, 2008
    6,147
    2,017
    In the country just north of Toronto, Canada
    I have the same issue with my G1. I use centre weighted metering.
  8. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    must be a canon/panasonic thing, lol. H
  9. Idahophoto
    Idahophoto TPF Noob!
    Jul 18, 2010
    389
    I live in Idaho
    It does a slight bit I think. I usually have mine set for 1/3 stop under exposure which seems to be about right most of the time. If the light is tricky I'll knock it down 2/3 but don't recall needing to go past that unless when I wanted it to be underexposed on purpose.
  10. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,475
    15,210
    USA
    Both my Canons, 20D and 5D, have a tendency toward overexposure at times. If all it takes is Minus 1/3 the problem surely isn't much of a big deal. My good friend Steve and I were talking a few weeks ago...he's recently begun shooting the Rebel XSi using Minus 2/3 stop, and has corrected a longstanding problem he's had when shooting in bright sunshine...with Minus 2/3 dialed in, his camera is giving him perfect exposures the majority of the time.
  11. robertwsimpson
    robertwsimpson No longer a newbie, moving up!
    Aug 3, 2009
    2,471
    30
    West Palm Beach, Fl
    weird. I leave my 50d at +1ev or thereabouts when shooting any of the auto modes. Are you shooting in JPG or RAW? I think JPGs overexpose and RAWs underexpose.
  12. TiCoyote
    TiCoyote TPF Noob!
    Apr 28, 2009
    624
    4
    New England
    I have found this problem with the 50D. I did a search on the 'net and I found that often the culprit is the "Auto Lighting Optimizer." It's a feature that is supposed to add fill light to dark areas. It can be set to 0-std, 1-low, 2-strong, 3-disable. The default is 0, but I find that 1 is better. The menu code to find it is C.Fn II -4. It's on p. 177 in your manual.
