Drying marks
Discussion in 'The Darkroom' started by will965, Dec 12, 2004.
  1. will965
    will965 TPF Noob!
    Nov 27, 2004
    214
    England
    Whats the best way to prevent or remove drying marks?
  2. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    usa. soon to be a euro boy.
    on film or paper or your jeans?
  3. Saeid
    Saeid TPF Noob!
    Nov 9, 2004
    50
    Persian Gulf
    LOL! Hehehehehe!
    U would believe hanging the print or negative away from any objects that it may get into contact. And with negative use a squeegee first. And make sure u have a nice air flow going around the room, so that it helps dry faster. :)
  4. oriecat
    oriecat work in progress
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    I have to disagree with squeegee-ing the negs (or paper even). That's just asking for scratches. I don't trust em.
  5. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    agree totally.
  6. Saeid
    Saeid TPF Noob!
    Nov 9, 2004
    50
    Persian Gulf
    Ya i kinda agree with u guys and i kinda dont, cause i've tried both ways (squeegee and no squeegee) and with squeegee it cuts down drying time by like 70%.
    Sometimes u really dont have the time. ;)
    Then again u should wet the squeegee before using, cause it will dampen it and reduce scratches and remove any dust particles.
    P.s. i forgot to mention this lastnight.. try hanging ur prints by one corner. So that the water all goes down to one corner, thus reducing the dry marks to at least one corner (not one side)... if that makes sense :S ;)
  7. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    For preventing drying marks on film I'd say use Photo Flo or some other wash aid, and use distilled water for washing.
  8. will965
    will965 TPF Noob!
    Nov 27, 2004
    214
    England
    Thx alot. Btw its for negatives I mean.
  9. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    Matt has it:
  10. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    Use a proper wetting agent - NEVER use anything else.
    Dilute according to manufacturers instructions and give film final rinse in it.
    NEVER use a squeegee - they harbour crap and give you scratches.
    Hang the film up. Wet you first two fingers with the diluted wetting agent, gently grip the film between the two fingers and run them down the film. Your fingers are sensitive and you will feel any grit - if you do, stop and rinse your fingers again and repeat.
    Wetting agent disperses the water over the film, using your fingers gets rid of the excess.
    Drying marks are caused by blobs of water left on the film and the salts evaporate out. If they are on the shiny side they can be polished off with a lens tissue - but it is best not to have them.
    Blobs of water on the emulsion side cause distortions in the emulsion through uneven drying. If you see any the best thing is to use your tongue to lick them off (it does work).
    Some people actually use distilled water for the last rinse (with wetting agent).
    It is important to dry films in a warm, dry atmosphere to minimise drying times. But too much heat will damage the film. In a shower cubicle is one of the best places - if you don't have a drying cabinet.
    Hope this helps.
  11. will965
    will965 TPF Noob!
    Nov 27, 2004
    214
    England
    Another question- with wetting agent, do i put it in and then immediatly takethe film out from the rinse or do i wait until the wetting agent has been washed off?
  12. Hertz van Rental
    Nov 8, 2004
    16,738
    46
    Where am I now?
    When you have washed the film - dilute the wetting agent as per the manufacturers instructions and do a final wash in that. I presume you are using spirals. Lift the spirals up and down in the wetting agent quite vigorously half a dozen times or so (you usually get suds forming) and that should do it.
    Do not rinse off the wetting agent as that defeats it's purpose.
