DSLR and filters?
Discussion in 'Photography Equipment & Products' started by RMThompson, Jan 13, 2007.
  1. RMThompson
    RMThompson the TPF moderators rock my world!
    Nov 12, 2006
    1,888
    11
    Do any of you use filters? Is it worth using a filter of any type on a DSLR when you can achieve similar effects in PP?
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    yes.
    well, many effects you cannot achieve in PS.
    - split neutral density filters cannot be replaced by PS action since the dynamical range of sensors is pretty limited
    - grey filters cannot be replaced by PS action
    - polarisers cannot be replaced by PS action
    - i am sure there are more ;)
    As for myself, on digital i do not use colour filters or any sort of effect filters (blur or whatever), since those can be pretty much mimiced by photoshop.
  3. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Not that I wouldn't recommend split neutral density filters (I do use one myself), but, you can get around this by shooting 2 exposures and combining them in photoshop.
  4. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    partially agreed. it works only with no moving objects at the borderline of bright and dark.
    so whenever you have a static situation you are right.
  5. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Partially agreed. :p
    You can also convert two exposures from 1 raw file. I've done this successfully many times when I didn't have a tripod to get two identical shots.
  6. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    think we reach convergence now ;)
    if the differnce in brightness is within certain limits, then starting with one RAW might help .
    sorry for getting carried away in your thread, RMThompson ;)
  7. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    All of my lenses have UV filters on them to protect the front element. They are on 100% of the time.
  8. nakedyak
    nakedyak TPF Noob!
    Sep 6, 2005
    451
    Columbus, OH
    yes. filters, yes. good.
  9. benwiggins
    benwiggins TPF Noob!
    Jan 12, 2007
    26
    asheville NC
    i use polarizers and UV filters.....
  10. ksmattfish
    Aug 25, 2003
    7,021
    34
    Lawrence, KS
    The only filters I use with my DSLR are polarizing and ND.
    A polarizer would be pretty difficult for me to duplicate in Adobe PS; much more difficult than using the pol filter in the first place.
    I use ND filters to keep the shutter speed down to the flash sync speed when using big apertures in bright sun. In bright sun the exposure can be 1/2000 @ f/4 with ISO 100. I want to get it down to 1/250th @ f/4, so I use a 3 stop ND.
    I carried split NDs in my film bags for a while. They were screw on style, so the split was always right in the middle. The sky in my compositions never fit the filter so I didn't really use them. Like Digital Matt, I just blend 2 or more exposures, or mix different exposures of the same raw file. This has been more useful for me than shooting with split ND filters.
  11. BAB
    BAB TPF Noob!
    Dec 28, 2006
    156
    Phoenix,AZ
    I would say yes to filters, because while some techniques and/or effects can be created in PS, some cannot. Also, IMHO it is far more efficient and better photography to get it right in camera, which translates into less time at the computer and in some cases better results.
are dslr filters worth it
dslr u. filters worth it?
which dslr filters worth it
