DSLR LCD Screen Protectors
Discussion in 'Photography Equipment & Products' started by phototrek, Aug 23, 2010.
  1. phototrek
    phototrek TPF Noob!
    Mar 10, 2009
    50
    I would like to know if anybody has used a plastic film protector on their DSLR LCD screens. I have read that some work and some don't work. That they are a pain to put on and trying to keep the bubbles out when applying. So who has used them and which brand did you like? Are there any that are anti-reflective? Have any of you scratched your unprotective LCD screens when using your cameras?
  2. KmH
    Apr 9, 2009
    40,724
    5,587
    Iowa
  3. JG_Coleman
    JG_Coleman No longer a newbie, moving up!
    May 30, 2010
    336
    28
    Wolcott, Connecticut, USA
    There are expensive film protectors, but in my experience, even the cheap stuff does the job just fine. You know... plastic film isn't going to help much if you smash your LCD into a rock, no matter how expensive it is... but the cheap stuff will protect against ordinary scratches just as well as the expensive stuff. And, frankly, you can by a whole package of sheets for a couple bucks... you can afford to replace them each month if you feel like it. The only difference, perhaps, between the cheaper brands and the custom, "made-for-your-camera" stuff is that you'll probably have to cut larger sheets of the cheap stuff down to size in order to get it to fit your LCD screen perfectly. It's pretty simple, really.
    They aren't the most painless thing to put on properly... bubbles, as you mention, are the most prominent problem... closely followed by getting fingerprints on the inner side of the film. It's all in the application technique, which may take a few tries to get right. I wouldn't call it difficult, there's just a small learning curve.
    I don't personally use them on my DSLR, since my D5000 has an articulated display that can actually be flipped around for protection. I have used them on various cell phones and iPods, though. I always make a valiant effort to put them on at least once when I first get an item, but I've never had the best of luck with them. They protect really well while they are applied... but it seems that no matter what I put them on, the film inevitably begins to peel off at the corners. At that point, if you don't replace them, the peeling will continue until they finally fall off or begin to detach enough that they are bothersome when trying to look at the display (in which case I just peel them off).
    As far as anti-glare, I'm sure that there are plenty of options... just keep in mind that, more likely than not, they will eventually peel off no matter what you pay for them. It's much less disconcerting to have 50 cents worth of plastic peel off than $10 or $15 worth. I recently got a "custom cut" plastic film cover for my iPhone 4... cost me $15 or $20. It lasted about two weeks before I pulled it out one day to find that it had peeled on one corner when I put it in my pocket and lint had plastered itself all over the detached corner. That's $20 down the drain... I wish I hadn't bought it.
  4. err_ok
    err_ok TPF Noob!
    Aug 6, 2010
    128
    Salisbury, UK
    I am glad that one came with my D700 I rarely take it off, only to remove dust etc... It is pretty battered.. the screen underneath is perfect.
  5. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,465
    15,207
    USA
    I never use ANY kind of screen protector...the LCD surfaces are quite tough...In nine years with d-slrs I have never scratched an LCD screen. I take the one that comes with the camera, and take it off,and throw it in a drawer. Live dangerously. Drive fast. Drink hard. PLay hard. Throw away the LCD cover.
  6. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    I always have a little laugh at those screen protectors...usually seen on Nikon cameras.
    I'm with Derrel...I've been using DSLR cameras for a while now, and I don't always baby them...and the screens are just fine.
    If you are really that worried about scratching the screen, then put the camera back into it's protective packaging and leave it there. :er:
  7. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    Giottos aegis screen protector made from schott glass is the only one worth anything... if u do decide to use one.
    Professional LCD Protectors
  8. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    I'm with Derrell on this one too.
    I don't baby anything, lol.
    Not a DSLR, but you see how my stuff looks :lol: :
    [​IMG]
    Looks bad, but it still works fine.
    Here's the LCD:
    [​IMG]
    You can see that the LCD took a pretty hard hit and no longer works. It is scratch free though.
    I have a lot of digital cameras, none of them have scratched LCDs...
    If I ever did get one, I think I would get one of those glass ones usayit linked to. That looks like it would actually protect from impact too.
  9. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Back when DSLR cameras were first becoming mainstream, I heard that factory replacement screens were going to be fairly cheap. $20-$30 for a screen etc. The only problem being that you'd need to open up the camera to actually change it, and that's not exactly a user friendly procedure.
    However, I don't think I've ever actually heard of anyone who's had their screen replaced...as so few of them are ever broken...or if they were, the rest of the camera was also damaged to the point where repair was too expensive.
  10. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    I have another camera with a broken screen (350D). It just died one day, no impact damage. When I turn it on, it just glows white.
    I would have replaced it myself, but it was just impossible to find a new LCD for it... You can't just go out and buy one.
    I never bothered sending it in, because frankly - it didn't bother me that much. I mostly shoot film anyway, so not having a LCD is no big deal.
    Now it's just too old to bother fixing. I'll probably just get a new camera body soon. (It's been broken for like 3 years now...)
  11. phototrek
    phototrek TPF Noob!
    Mar 10, 2009
    50
    Thanks guys for your input. I really don't one to put one on my DSLR. I don't abuse my camera gear so I don't see why I would need one.
  12. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    The glass ones look nice, and they should protect it from impact damage (what killed the LCD on the A520 that I posted above). For that, it might be worth it.
    If all you're worried about is preventing scratches, I would skip it. Those screens are pretty tough.
    Impacts can kill an LCD, but that can be (mostly) prevented by not abusing your gear. Of course, you never know when an accident will happen...
    In the case of my 350D, I think it was just a manufacturing defect that would have happened with or without a LCD protector.
best camera screen protector forum
best dslr screen protector
best screen protector for slr screen
do dslrs need screen protectors
does dslr need lcd protector
how to protect dslr screen
protector lcd dslr
screen protectors for dslr
should i use screen protector for my dslr
