Dust inside a lens
Discussion in 'Beyond the Basics' started by KaraM, Jan 29, 2007.
  1. KaraM
    KaraM TPF Noob!
    Jan 16, 2007
    54
    Texas
    I think I have some dust on the inside of my lens (Canon 135mm f/2.5). Can I clean that? If so, how difficult would that be? If I shouldn't do it myself, can a camera shop clean that? About how much should it cost?
    Thanks
  2. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    if the dust is inside the lense....the chances is that you wont be able to clean it yourself....you dont want to break the seal and introduce more dust into the system.......and very often those little dust particle do not affect your image quality.....and i would not recommend clean it from anywhere....as far as i concern....i believe the original lense should have some kind of seal to prevent dust from entering....once you open it and dotn have proper tools to put it back with the seal.....you will end up getting even more dust in later on
  3. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,524
    448
    Dust inside the lens simply means the lens was used outside when it was breezy or windy. Every lens gets a little dust inside. It won't hurt your images. Don't give it another thought.
  4. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    I agree. Unless you are seeing something in the prints, I wouldn't worry about it. I use lenses that scare me when I hold them up to the light.
  5. memorex88
    memorex88 TPF Noob!
    Nov 19, 2006
    123
    Montreal, Canada
    and if you must get it cleaned, send it to Canon!
  6. Chicagophotoshop
    Chicagophotoshop TPF Noob!
    Jan 25, 2007
    395
    Chicago, IL USA
    I would recommend getting it cleaned. I did that with mine. cost about $60 but well worth it.
  7. Christie Photo
    Christie Photo No longer a newbie, moving up!
    Jan 7, 2005
    7,042
    80
    Kankakee, IL
    Absolutely right. There would have to be quite a bit of dust... a BUNCH of dust before you'll see any softening of the image.
    Pete
  8. fmw
    Sep 30, 2006
    3,524
    448
    I strongly disagree. Not only do you run the risk of getting a lens element misaligned but the dust will return as soon as you use the lens again. Do not get it cleaned.
canon 18-135 lens cleaning
